586,655 active members*
2,413 visitors online*
IndustryArena Forum > CAM Software > CamWorks > 4th axis machining tapered floor
Results 1 to 3 of 3
    Jul 2005
    1650
    I need help machining the floor to a path that is wrapped around a wheel
    I have been able to get the software to get close but cannot get it right I machine the floor to upper depth and now want to put the taper in the floor..
    I would like to mill from lowest pint to highest point width is .0179 tool is .012
    I can send file to someone who can help I have solidworks and camworks 2013.. if you need more info please let know
    thanks
    Jul 2005
    1650
    Re: 4th axis machining tapered floor
    I also have Camworks and solidworks 2011 if I could get pointed in the right direction it would be helpful
    May 2005
    15
    Cruizer,
    It is hard to tell from the attachment what you are trying to do. If you can upload the solid model I could take a crack at it. Also need to know what material you are machining.
    Harvdog
  1. Replies: 1
    Last Post: 03-09-2014, 01:36 AM
  2. Replies: 0
    Last Post: 10-24-2013, 04:49 PM
  3. X3 Z axis tapered gib
    By binfordw in forum X3/SX3/G0619/G0463
    Last Post: 04-19-2013, 03:14 PM
  4. Flow 5 Axis Machining on X-Axis
    By pvmachine in forum Mastercam
    Last Post: 09-20-2012, 08:29 AM
  5. 5-axis vs 3-axis machining rigidity
    By Gabe Newell in forum MetalWork Discussion
    Last Post: 03-15-2011, 04:54 PM
