586,570 active members*
3,390 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > scm routech calibration problem
Results 1 to 3 of 3
    Dec 2014
    2
    after yaskawa serwopack was repaired ( by yaskawa-usa ) and wired back I can not calibrate machine. n40 excessive following error on axis 0 is displayed .can somebody help?
    scm routech routomat num 1040 cnc 2 heads year 1999
    Sep 2010
    1765
    Re: scm routech calibration problem
    hi marcela. unfortunately, nowadays it is not so uncommon for repair folks to not really repair drives right or fully. even the OEM mfgrer.
    that said, think of what causes FE. I will assume it is a analog drive with +/-10v speed command input. so if the repair tech changed the analog input scaling (is it a front panel pot?) then you may get fe problems. so if you have info on the drive, I think first think I would check is ana input voltage: if it saturates to 10v then you get FE fault.
    are you getting current to the motor?
    does it run at all? can you turn FE off for a test in control and see what happens?
    Dec 2014
    2
    thank you Mike
    drive was send to scm group for check up and now we are just sitting and waiting (customer service!)
  1. problem with cnc scm routech record 220 with num 1040 controller
    By mahamaha in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-27-2016, 05:10 PM
  2. CNC MACH3 Calibration Problem
    By rognets in forum Calibration / Measurement
    Last Post: 04-16-2012, 04:12 PM
  3. Calibration problem
    By Bell 430 in forum Shopmaster/Shoptask
    Last Post: 05-05-2011, 08:55 PM
  4. Routech 250 Twin Table problem
    By Travisty in forum Commercial CNC Wood Routers
    Last Post: 10-28-2009, 06:40 PM
  5. Renishaw Calibration Problem on VF2
    By Mic6 in forum Haas Mills
    Last Post: 07-10-2009, 02:29 AM
