Hey Y'all! Just wanted to start my design/build thread here. I've got a few questions I need answered and a few decisions finalized, then I'll be ordering everything for my first dive into CNC machining (well, routering?). My plan is to order most of the Benchtop Basic CNC Machine Kit (Benchtop Basic CNC Machine Kit | CNCRouterParts) from CNC Router Parts less the included 80/20 extrusion. I'm going to buy my own custom-length extrusion in order to expand the benchtop basic to a cutting area greater than 24" x 24".
I've already been in communication with Ahren, who is probably one of the most helpful and open vendors I have ever dealt with, personally or professionally, and he has given me prices on the hardware kit sans 80/20 extrusion, pre-wired electronics kit and upgraded components to elongate the Y-axis. He did request I not divulge these prices as they are not listed on the website and subject to change, especially if more people start ordering piece-meal instead of the whole machine.
Just wanted to get that out of the way early.
Basically, I have a few key applications that require a minimum of 24x24" cutting area, so all the smaller chinese benchtop machines were out as I haven't seen one with any axis over 18", and most seem to be 12" or less in both X and Y. This router will be for home/personal use only at this point, and as such, must fit in my small two-car garage where we currently park two cars (novel, huh?). It also must be approved by the wife, so really anything over maybe 2 ft x 3 ft was out. I really took a liking to CNCRP's Benchtop Pro, particularly the V-Con system. I can't really explain why I like this over the simpler ABEC bearings and flat steel plate, but I'm pretty stubborn and when I decide I like or don't like something, that's the way it's gonna be. The one major drawback to the Benchtop Pro was price--at almost 3 grand without electronics, I could see that going well into the $4,000+ range.
I really liked the idea of a dual-driven X-Axis in the event that I wanted to cut hardwoods or get into some aluminum plate, not only for rigidity, but also because I don't want to wait all day to cut one piece. So I began trying to figure out if I could take the standard ACME drive parts, including the dumpsterCNC nut, along with V-Con brackets and recreate the Benchtop Pro on the cheap. I learned quickly that the only way the Pro works is due to the custom extrusions with ballscrews for each axis. The ballscrews are mounted in the middle of where typical extrusion would be. If using standard V-Con clamps and normal extrusion, you have to mount the screws in such a way that the ACME nut wouldn't clear the linear brackets as the gantry moved along the axis.
That brought me to the basic. It already uses ACME instead of ballscrews and the bent V-Con plate provides ample clearance for ACME nuts to traverse without interference. It has an integrated electronics package that fits directly onto the machine. And the price was right. So away I went, modeling in Solidworks to figure out exactly how long of pieces I needed to order from 80/20. See below for my first take.
Attachment 262190 Attachment 262192 Attachment 262194
After playing with many models in many different configurations, I realized that in order to take this kit and make it dual-X driven, I would need to fabricate custom risers in order to mount acme nuts. Because this is my first machine, I do not have the capability to do so, and if I went out and had them made, I might as well spend the same money and get the PRO.
I'm still fiddling with the design, but I would like to know if anyone has purchased the normal Basic kit and how they like it? With such a small distance between risers, is being out of square a problem with a machine such as this? The spec page says the normal-sized 18x24 machine will do 200IPM. My design has a heavier gantry, so I suspect this would go down unless I figure out a way to dual-drive the X.
I have already purchased a Bosch 1617 (single-speed 25k, motor only) on sale via amazon, and plan to buy a SuperPID for speed control. This leaves me with another design hurdle, as the integrated electronics enclosure is fits perfectly between the normal machine, but space would need to be taken up with a widened machine. You can see this preliminary design uses extra extrusion to fill the gaps, but I don't really like it. Also, the enclosure is pretty much full as-is, leaving no room for me to add the SuperPID. I plan to order the electronics kit as a DIY with no enclosure, and either build or find one to fit.
So, what are your thoughts? Any comments or advice on single vs dual-driven X-axis? I've read a ton here on the zone, and specifically http://www.cnczone.com/forums/linear...rews-axis.html, so it seems like dual-driven is relatively easy to slave an axis. Since I have no way currently to fabricate new uprights, I have to get a standard 3-axis to start. The next big decision I have to make will be to decide whether or not to buy electronics that would enable to me to upgrade once I could make my own uprights.
I'm off for the holidays so I'll be updating this thread a lot until I'm able to order everything and get it here. I've (my wife) also got a baby on the way, and that will likely put a hold on things for a little bit, so I'm trying to get as much done on this as I can before she comes. Anyway, thanks in advance for any comments or suggestions.
Matthew
