587,008 active members*
3,743 visitors online*
Results 1 to 9 of 9
    Aug 2008
    16
    m900 redsail 100 watt reci tube
    i am looking into buying the redsail m900 100 watt reci tube. does anyone have this machine or any thoughts on redsail. i would like to speak with someone in the states who is using this machine. if anyone out there who would like to share experience please call 757-288-6256
    thanks
    mark
    Re: m900 redsail 100 watt reci tube
    I have a M900, with the standard 80w tube not the Reci. Decent machine, tho not the best software in the world. Import of the machine went quite well. Their support isn't all they claim it to be, but most issues I've been able to figure out myself without need of their assistance. The software updates can be downloaded off the net. I'm running LaserWork v6, tho v5 came with the machine, v6 works fine.
    Hello dear friend,
    Have a nice day!
    This is Anwaar from Redsail company and if you need our laser machine please contact me.
    Email:[email protected]
    Skype:redsail-anwar130313
    Welcome
    Oct 2012
    30
    IMO stay away from that company: I bought a M700 a year ago, and I have had nothing but problem with it. Right now, it's no longer working, and nobody is getting back to me from Redsail, to help me solve this issue...
    Back a couple of months ago, tech support was so-so, now it's literally nonexistent.
    I consider my 3500$ investment, a total waste ....
    Hello Mark.
    This is Anwaar from Redsail and glad to sepak with you about M900 laser machine.
    May i know your email?Then i will send details to you.
    Thanks.
    May 2016
    30
    Quote Originally Posted by DasWookie View Post
    So Laser work is Working with M900?
    Have you tried other software? If yes which one is best?
    Klaus
    Quote Originally Posted by Klausm2 View Post
    Klaus
    Yes, RDCam/LaserWork v6 works, but it's the controller you are using in your machine that matters. The default controller that comes in the M900 will indeed. I've since upgraded to the controller with the color display, which allows adjustment of individual layers settings on the machine itself, rather than having to go back to the PC, change the settings, and resend the job, as well as has an Ethernet connection so I'm no longer tied to the machine with the short USB cable.
    As far as I know, the controller only works with their software. I'm sure you could probably hack up something once you figured out the protocol, but it works well enough that I've not had any real desire or intention to try to get something else to work. Most software is either going to work via USB and send the file to the laser, or it's going to work with a different pseudo-printer driver, like the Epilog. The major key is, where are you doing the design of your file which is what makes the major differences. I use Adobe Illistrator. Lots of folks prefer Corel, but I've always been an Adobe guy so haven't really tried to figure out how to do the same stuff in Corel. Either works tho. You're just outputting into a file format that the controller software can read (all the same, but primarily DXF or AI for vector graphics, or JPG/GIF/PNG for raster), selecting that layer and setting a speed and power level, and hit GO.
    May 2016
    30
    Cool Re: m900 redsail 100 watt reci tube
    Im not sure I understand you correct, are you still using Laserwork V6 after updating to the Color display? Or are you saying you can't use it anymore? Sorry English is not my first Language.
    If you can't use it anymore, what are you using instead?
    Im a Graphic Designer so I am also like you using Adobe Illustrator. So LaserWork can us e AI files? Or do you have to save/export them as DXF files?
    How god is the Raser output from LaserWork? Are you happy with the quality?
    Have you tried other software? If yes, which one, and which one do you think is the best?
    Sorry about all my questions
    May 2016
    30
    One more thing, is RDCam and LaserWork the same software? A little confusing because there are also RDWorks 8 wich also seems to a Laser software?
  1. problem with PSU wiring for 80W Reci CO2 tube - only getting 4 mA output to tube
    By gbatten in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-06-2015, 12:53 AM
  2. Optics for Reci W8 170 Watt CO2 Laser
    By rutexus in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2013, 03:39 AM
  3. Redsail M900 Cutting Performance
    By REDSAILER in forum Redsail Laser
    Last Post: 08-06-2012, 01:05 AM
  4. Redsail M900 from Sara in China
    By ltlbull in forum Redsail Laser
    Last Post: 12-21-2011, 08:09 PM
  5. Redsail M900 or 6090
    By iburton in forum Redsail Laser
    Last Post: 03-03-2011, 10:18 PM
