586,950 active members*
2,775 visitors online*
    Jul 2006
    Unhappy Engraving acrylic, which bits
    I am new to CNC and I am trying to engrave acrylic. I am doing small letters about .2" tall. I am using a small 'D' type V bit with a .01 tip and 50 deg angle. I have problems with heat build up and gumming up bits. My router will run from 1000 rpm up. I am cutting about .01 deep. I've tried multiple passes, light oil and water for lube. I've tried IPM from 8 to 20.
    Still I am not getting 100% good engraving.
    Any suggestions would be great.
    Larry Naumann
    Oct 2004
    12
    I like to use ball endmills, 3/64" is my tool of choice.
    I typicaly engrave at 6000rpm and about 5-10ipm going about .005" deep.
    I also use air to cool my parts.
    183
    Either change to cast acrylic or use air to cool, i cut cast without any meltiing at .25 per pass and extruded at .125 per pass with air, no melting. spindle speed of 8000, about 40ipm
    Jun 2006
    629
    Used a 1/16" ballnose endmill @8000 RPM
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Apr 2008
    59
    Larry,
    I'm doing drag engraving of acrylic. No rotation = no heat.
    I have posted a video here:
    http://www.cnczone.com/forums/showthread.php?t=104920
    The first part of the first video shows my first acrylic test.
    Cheers,
    Bob.
  1. Engraving acrylic, how to clean it?
    By Things in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-26-2019, 04:45 PM
  2. engraving acrylic or wood
    By mrlttlman in forum Engraving Machines
    Last Post: 06-01-2013, 04:07 AM
  3. Engraving (glass and acrylic)
    By fibonacci in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-02-2010, 11:47 PM
  4. Acrylic engraving
    By ARTILLERO in forum Material Machining Solutions
    Last Post: 05-11-2010, 12:11 AM
  5. What bits to use on acrylic
    By reeftoker75 in forum Material Machining Solutions
    Last Post: 08-31-2007, 04:04 AM
