OK, So I am pretty certain I'll need to dump the Allen Bradley Bandit III controller from the early 80's. (prior post). I will upgrade to a newer style motion control and servo driver set. I like this kit from Ajax but again, need to select something that will play nice w/ the CAM Post processor. Do you know if one of the 'current V12 CAM posts will work for Centroid? They also offer Mach3 so that can be a backup plan. I just wanted to get away from Mach3 on the larger supermax mill.
Ajax CNC CENTROID Software | CNC Retrofit Control Systems for Milling machines, Routers and Lathes. Runs Mach3 or CENTROID Software
Ajax CNC Centroid Mill Kits | CNC Retrofit Control Systems for Milling machines, Routers and Lathes. Runs Mach3 or CENTROID Software
Thanks everyone. It will cost me about $400 for a set of allen bradley 80's bandit III manuals, a 232 comms cable setup. I may as well upgrade now and save a lot of time.. . .
