586,523 active members*
3,378 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 3D Cutting a Negative Taper with X7.
Results 1 to 4 of 4
    Dec 2014
    3
    I am trying to cut a 4 degree negative taper with a 6 degree dovetail type tool with a .010" corner radius on it. I got it to cut right with a Surface Flowline tool path but can't get it to retract without gouging the part. How do I get it to go to the center of the taper before retracting? Or should I try a different type of tool path?
    I am using a Makino 3-axis machine.
    May 2008
    667
    Re: 3D Cutting a Negative Taper with X7.
    I don't know exactly, but I would just manually add something like G0 X0.0 Y0.0 before the Z+ move.
    Jeff
    Oct 2014
    14
    I generally try and avoid inserting any thing manually after posting. Should you need to re-post for any reason and forget that crucial line you're dead. I faced the same situation with an undercut area once and a fellow programmer suggested a work around that sounds kind of hokey but actually worked quite well.
    1. Backplot existing program and save as geometry.
    2. Create a line from end point of final segment of cut portion of toolpath to center of taper. create another line that represents retraction along Z axis to clearance plane
    3. Create a contour toolpath and select 3d mode. Chain modified toolpath with added retraction moves.
    4. Ghost reference toolpath rather than delete in case you want to modify later.
    With this method you can confirm results through backplot and verify.
    Ray
    NX 9.0.3.4 MP1
    Dec 2008
    3110
    A Surfacing strategy has an option to adjust the lead on/off of a tool, not just by some strategies having the ability to add an arc &/or an extension line
    Look for the "Direction" option.......NOTE, do not set this until you have done ALL the other adjustments of the tool on the job paths
    left side for the approach, right side for departure
    ...this is a global setting for ALL tool contacts in this operation.... so everything must be looked at carefully, as it is NOT part of gouge checking, it is not "gouge checked", nor is it actually part of the toolpath that contacts the drive surfaces,,,,,these are little moves tagged onto each end of each cutting pass
  1. Cutting taper on TL-1
    By AJ961 in forum Haas Lathes
    Last Post: 08-28-2014, 12:15 AM
  2. cutting a taper on titanium rod
    By marty7001 in forum MetalWork Discussion
    Last Post: 05-21-2014, 02:06 AM
  3. Mastercam 9.1 Undercut/negative taper
    By granth3 in forum Mastercam
    Last Post: 12-11-2011, 05:56 PM
  4. Lathe cutting a taper
    By eartaker in forum Mini Lathe
    Last Post: 01-24-2011, 07:45 AM
  5. taper thread cutting
    By cncmc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-05-2008, 10:59 AM
