586,547 active members*
3,221 visitors online*
IndustryArena Forum > Hobby Projects > Hobby Discussion > My Gingery Inspired lathe project
    Dec 2014
    33
    So, a few months ago I got really excited about Gingery's workshop from scrap series.
    I managed to get my hands on a blown aluminum trans am block from the mid 90 as my source of aluminum.
    As I went through the process of researching further and starting my build, I realized that there were easier, better ways to do some of this stuff that were actually cheaper as well.
    I have since realized that perhaps i should try utilizing other materials for my lathe, while keeping true as I can to the design.
    I salvaged the crankshaft supports (steel or cast iron?) to use as my lathe feet, and am using bought steel tubing/flats for my lathe bed. I am thinking of later filling the tubing with epoxy granite.
    I will give credit to this guy for inspiring me to use tubing instead of a casting for my bed: Lathe
    Anyways, this thread will follow my development. I'm not sure if this will really be a Gingery lathe when done, but certainly inspired by it.
    Pics attached to this thread of how I am starting out.
    Dec 2014
    33
    Re: My Gingery Inspired lathe project
    Hmm, I had created this thread then it disappeared. Now it's back after I created it elsewhere.
    http://www.cnczone.com/forums/vertic...ml#post1615360
  1. Gingery lathe build - ways material choice
    By tempr in forum MetalWork Discussion
    Last Post: 01-12-2017, 02:58 AM
  2. Gingery lathe largest
    By kakuma in forum Mini Lathe
    Last Post: 02-12-2014, 05:19 PM
  3. Building gingery lathe bed
    By slackwarerobert in forum Uncategorised MetalWorking Machines
    Last Post: 06-30-2010, 10:41 PM
  4. Gingery Style Mill
    By JBV in forum Mechanical Calculations/Engineering Design
    Last Post: 09-26-2006, 08:25 PM
  5. Gingery style rails??
    By randyf1965 in forum DIY CNC Router Table Machines
    Last Post: 04-08-2005, 10:15 PM
