I've got a relatively simple part I'm trying to cut with my new CNC router it is a leg for a bookcase with rabbets for the shelves to slide into -- I have designed in ArtCam Express, my machine is running Mach3 (4 x 8 Green Lean vertical machine). I've made the vectors, I've set up the tool paths for both area clearance for the rabbet and the profile for the cutting out. I've figured out bridging which is super important on a vertical machine as well. The problem is with the 1/2" wide rabbets. The machine is making them 0.41 inches per my caliper, and while in ArtCam they do show 0.5, also I'd like to get the CNC to mill them a hair past the profile cut so that once cut out the rabbet runs edge to edge rather than leaving a sliver of material for me to cut out later manually. I am going to guess these are probably related to tool offset but I'd like to find out before I move further. I thought it might be a calibration issue as well, so I tested that, and its spot on. The distance between the rabbets is also correct so that would lead me away from it being a calibration issue as well.
Please let me know what to look at. Any help is appreciated.
Merry Christmas to all
Chris
