586,389 active members*
3,046 visitors online*
    Jan 2007
    11
    segment to short
    When I post the G-Code from VisualMill there are at times a few redundant values in the G-Code , most controllers just pass it through no problem the CamSoft CNC Plus gives me a segment to short error ,can this be fixed somehow.
    EXE . G83 X0. Y0. Z-1. R0.1 Q0.1 F5.
    G00 Z0.1 ----- ERROR:SEGMENT TO SHORT (rapid plane Z is same as R value)
    I know I can fix most of this in the posting of the G-Code but sometimes I forget and it gets real anoying to deal with.
    Mar 2004
    1543
    Re: segment to short
    Can I see your G83 in Gcode.fil?
    It very likely calls a macro in macro.fil, maybe[[G83]], can i see that too?
    Karl
    Jan 2007
    11
    I have attached the entire .cbk file ( I just changed .cbk to .txt to upload it) . The proble happens often when sprial pocket cutting and when ramping into pockets the G83 was just a quick example.
    Apr 2003
    332
    Klm123
    The message (rapid plane Z is same as R value) is letting you know the rapid move G00 Z0.1 is the same as the R0.1 value in the G83 canned cycle on the line before. Z would not move. It's only a message. The message has been removed many years ago in CNC Lite. Your system is 9 1/2 years old.
    No need for this line G00 Z0.1
    The R0.1 (rapid clearance plane) in the G83 canned cycle rapids to the same place.
    You may either delete this line or else use a slightly higher Z to rapid too to be safe.
    Tech Support
    CamSoft Corp.
    [email protected]
    PH 951-674-8100
    Fax 951-674-3110
    PC Based CNC Controller For The Machine Tool CNC Retrofit And CNC Controller OEM Market
    Mar 2004
    1543
    Sorry, I was gone a while...
    I am a CNC Pro user. Could have easily trapped this error in Pro. Looks like the fine techs at Camsoft have your only answer for Lite.
    Karl
  1. Bad segment number
    By M Todd in forum Community Club House
    Last Post: 06-17-2013, 05:47 PM
  2. What to use as tinted cover for 7 segment display?
    By SCCoupe in forum CNC Machine Related Electronics
    Last Post: 08-06-2009, 07:36 PM
  3. Sinumeric 840D - 7 segment LED
    By Cleverel in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-25-2009, 12:45 PM
  4. 16F84 7 segment display
    By Razer in forum PIC Programing / Design
    Last Post: 06-10-2009, 05:27 PM
  5. Replies: 5
    Last Post: 10-02-2008, 04:28 PM
