586,852 active members*
2,291 visitors online*
    Aug 2014
    29
    Milling an angle
    I am trying to mill with a ball mill, but to avoid the line it leaves in the middle of the groove, I want to mill at an angle, 17 degrees to be exact. I made a set of parallels with my plasma cutter to set the stock at 17 degrees. According to my calculations, z needs to travel 9.934" and z needs to travel 2.904". I need the z axis to move at a slower rate than the x axis. I have been trying to do this in BobCad, but I'm just learning how to use it, and havent figured it out yet. Is this possible to write out manually?
    Aug 2014
    29
    Re: Milling an angle
    A buddy of mine said to look into interpolation... if you guys have any info on interpolation, it would be very helpful
    2932
    You don't say what control you have, but most CNC mills have G01 Linear Interpolation, which will "interpolate" a straight line from the current position to the commanded position. Most also have G91 Incremental Positioning mode, which specifies that any axis command that follows will be a distance rather than a position.
    G00 G90 X0 Y0
    G01 Z0 F20.
    G91 X9.934 Z-2.904
    Y0.02
    X-9.934 Z2.904
    Y0.02
    X9.934 Z-2.904
    Aug 2014
    29
    aaaahh, ok I believe I get it now. I know my machines support linear interpolation. I figured that both axis would travel at the same feed rate with G01, so I figured wrong. Thanks
  1. Adjustable angle plate for milling
    By jeffrey001 in forum Canadian Club House
    Last Post: 03-27-2013, 07:09 AM
  2. Milling machine, angle head, CAT-40
    By mvoss_chemiflex in forum Want To Buy...Need help!
    Last Post: 08-13-2011, 06:56 AM
  3. Variable angle milling head
    By glsmaverick in forum Haas Mills
    Last Post: 09-02-2010, 05:36 PM
  4. Milling on an Angle
    By Mihelich in forum MetalWork Discussion
    Last Post: 06-26-2009, 08:38 PM
  5. Milling Angle Headache!
    By ADVANCED MACH. in forum MetalWork Discussion
    Last Post: 12-07-2005, 02:46 AM
