587,003 active members*
3,012 visitors online*
IndustryArena Forum > CAM Software > Esprit > alarm for feeds&speeds
    Jul 2014
    222
    is it possible to set up esprit somehow so when you start a new program it asks you which material youre working in and it automatically recognizes regular feeds and speeds range so that if youre working in steel if you by mistake enter cutter feed of 5000 mm/min it will show alarm message which asks you are you sure you want to enter that number?
    or if it recognizes some tool left in feed or speed regularly used for aluminium or plastic, it will alarm user?
    today almost had an accident where the feed was entered by mistake with one 0 more and almost crashed machine.
    Sep 2008
    18
    Re: alarm for feeds&speeds
    yes, this can be accomplished through a combination of KBM and VBA or strickly VBA. Most likely I would create something in VBA though an autorun procedure for something like this. If this is something you would like to pursue let me know.
  1. Speeds & feeds
    By nateman_doo in forum Benchtop Machines
    Last Post: 11-21-2011, 02:54 PM
  2. Speeds and Feeds
    By fenix in forum Uncategorised CAM Discussion
    Last Post: 01-22-2010, 07:07 PM
  3. Help Please Feeds and Speeds
    By mtcnc in forum Uncategorised MetalWorking Machines
    Last Post: 01-21-2010, 10:36 PM
  4. Feeds and Speeds
    By mtcnc in forum Material Machining Solutions
    Last Post: 01-21-2010, 10:34 PM
  5. Speeds n Feeds
    By jessbussert in forum WoodWorking Topics
    Last Post: 06-12-2008, 05:09 PM
