586,102 active members*
2,573 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > 1991 LB-15 QUESTIONS
    Oct 2013
    Hello all, i am very raw when it comes to CNC Lathes as i have been programming and operating CNC Mills for 12 years. The new company i am at currently has an LB-15 with a 12" chuck on it and i am trying to get some info to get a Hardinge 25C adapter assembly. My questions are, where do i find the actuator manufacturer? Draw Tube / Bar Thread left or right hand and internal or external? Distance from Front of Spindle to Front of Draw Tube / Bar when Forward and Retracted? And also i believe it has an A2-6 Spindle but one thing that threw me for a loop was our draw tube ID is 2.562" and in the specs all i can find are that it should be 2.200". Any help would be greatly appreciated.
    Apr 2009
    1262
    Re: 1991 LB-15 QUESTIONS
    I think you have the big bore spindle which has an a8 nose if I remember correctly. You should have the actuator model stamped into a plate on the front of your machine. They typically were Kitagawa actuators and chucks. I May have some of those drawings if your Okuma rep can't provide them.
    Oct 2013
    We do not have an Okuma rep that i know of, the machine was purchased from some shop for like $2,500 it runs great i am just trying to make it more production friendly as we are typically just running standoffs and parts like that. If there is any way you could get me some drawings for the big bore machine so i can confirm it then that would be great. I cannot find hardly any information online about draw tube diameter or cylinder diameter. I have been looking for quite some time and finally decided to ask in here.
  1. 1991 VF1 RS232 Problems
    By lovell110 in forum Haas Mills
    Last Post: 02-19-2020, 03:20 PM
  2. Looking at a 1991 VF1 possible purchase
    By speed33317 in forum Haas Mills
    Last Post: 04-29-2014, 02:58 PM
  3. 1991 leadwell vmc..what do I look for as far as wear?
    By acannell in forum Maintenance DIY Discussion
    Last Post: 03-26-2013, 08:12 PM
  4. 1991 QT.15N
    By dcchip in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-08-2011, 10:24 PM
  5. Help with 1991 VF1?
    By david bright in forum Haas Mills
    Last Post: 07-20-2007, 12:27 PM
