586,154 active members*
3,839 visitors online*
Results 1 to 8 of 8
    Mar 2013
    4
    Amada RG 80 Press Brake Problem
    My RG 80 Press Brake will not go above 20 tons on a bend. I get no alarms or indication of problem. Has anyone had this issue?
    Jun 2006
    198
    Re: Amada RG 80 Press Brake Problem
    Check oil levels....
    Apr 2008
    17
    Check the relief valve on the left end. Also the adjusting bolt that pushes the rod into the distribution valve might have worked loose.
    Hope this helps,
    Tom
    Aug 2013
    4
    Mister NCT has suggested just what to do, The rod that connects your bar pedal to the valve rides on a bolt with a jam nut. You only want to take up the play, so you should still be able to spin the rod with two fingers.
    Mar 2013
    4
    The problem was the relief valve. Thank you for your help!!
    you can read the press brake troubleshooting article, it list 17 common problems and the solutions: https://machinemfg.com/17-press-brak...sons-measures/
    Quote Originally Posted by MachineMfg View Post
    Nice article!
    May 2020
    6
  1. Amada Press Brake Controller problem
    By jamesbond007 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2018, 03:38 AM
  2. Amada Press Brake
    By Footballwr46 in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2018, 03:29 AM
  3. Amada Pega 344 Punch Press Clutch/Brake Assy Breakdown
    By tony@sm-w in forum Community Club House
    Last Post: 03-15-2012, 12:16 AM
  4. Amada PRESS BRAKE HFT 220-3
    By M7MED in forum Bending, Forging, Extrusion...
    Last Post: 12-30-2011, 03:04 AM
  5. Amada brake press controller nc9 r
    By maplesiport in forum Controller & Computer Solutions
    Last Post: 07-15-2010, 11:32 PM
