586,655 active members*
4,108 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Help 15901 SPDL ORN FAIL-Cincinnati Sabre 750
    May 2014
    16
    I have a Cincinnati Sabre 750 and it is giving us intermittant 15901 SPDL ORN FAIL. It only does it on certian tools (ones used to Rough out metal). It has done it on different programs that we have used for years, on stainless steel & aluminum. After it roughs out the metal it puts the tool back then will alarm sometimes, most times and all the time. The operators have shut the machine off for 5 or so min and it will be fine. What could it be? Spindle getting too warm ? have touched and it or the tool dosent feel warm.
    Thanks for any and all help! Dan
    Sep 2010
    1765
    Re: Help 15901 SPDL ORN FAIL-Cincinnati Sabre 750
    Quote Originally Posted by Hydratight View Post
    Dan,it would be useful if you add a LOCATION to your profile so folks can see where you are located.
    This error is typical when our battery backed ram dies; it had a design life of about 6 years; your machine is probably close to 20 yrs old.
    To replace the spindle VFS5 BRAM requires reprogramming proprietary info into it; not something you can do at home.
    Dec 2006
    584
    Dan,
    You need to check if you are getting the proper knock out of the tool. When the tool is un-clamped it should hit the back of the tool and push it out about 0.030" when you are holding the tool. If the drive key is out of position when the tool drum moves to pick up the tool it will push the drive key out of position and cause the error. You do need to add your location as Mike K said !!!
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Dec 2006
    584
    Dan,
    You also need to add the control model and the model of the axis and spindle drives to get correct answers.
  1. cincinnati sabre 500 vmc
    By bpt001 in forum Community Club House
    Last Post: 01-31-2014, 03:20 AM
  2. Cincinnati Sabre 500
    By leggetmachine in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2011, 05:14 AM
  3. Help with Cincinnati Sabre 750
    By ctaktak in forum Community Club House
    Last Post: 07-04-2010, 10:31 PM
  4. Help! with Cincinnati Sabre 750 CNC
    By cgerchow in forum Cincinnati CNC
    Last Post: 01-13-2010, 11:37 PM
  5. Cincinnati VMC Sabre 750
    By HTMDGEARY in forum G-Code Programing
    Last Post: 06-24-2009, 05:50 AM
