586,461 active members*
4,257 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Profile Rail, 2 race vs 4 race lm guides
    Jan 2013
    52
    Got off the phone earlier today with a seller, talking about the differences between the two types of lm guides whether it be nsk/thk/hiwin etc..
    It came down to him saying that 2 races are very capable, have very little backlash (if any)
    He said 4 races typically have maybe a 10% increase in ratings (I'm just starting to look into lm guides), which I haven't backed up myself with research (don't know what values I'm looking for really).
    It was also mentioned that many people tout the 4 race bearings as superior due to nsk and thk really hyping them up and using it as a marketing ploy to single out the 2 race types.
    Thoughts, opinions, and real world experiences appreciated.
    ____
    I'm considering a machine based on 2 race hiwin lm guides. Cutting envelope of ~36"x48". Combination of wood/aluminum/(steel may be ambitious, but would be interesting to try)
    At a very basic level here is my thoughts on design (all based on 20-30mm 2 race rails and aluminum extrusion from 80/20. Acme drive)
    X axis gantry, 2 rails that support the z axis w/ 1 bearing block on each rail.
    Y axis, 1 rail on each side mounted to the moving gantry via 2 bearing blocks (per side)
    I'm undecided on what size extrusions to use. I was going back and forth between 25-5010 and 3060 for the gantry w/ .75" aluminum side plates for the gantry
    For anyone who is on the zone alot and can think of a good build log that goes along those lines, drop me a link
    Jun 2010
    4256
    Re: Profile Rail, 2 race vs 4 race lm guides
    If you are putting 100 kW through the shaft and driving several tonnes, then a 4-race system might be worth looking at. Mind you, roller bearings would probably be far more appropriate.
    For a router with an aluminium frame? Fergedit. Way way overkill.
    Cheers
    Roger
    EDIT: I think I screwed up here. I was talking about circular ball races, not linear rails. Total stuff-up by me.
    Yes, I suspect linear bearings with 4 rows of balls are going to be a bit better than ones with just 2 rows, at least under heavy variable loads. Less room for slop - although none of them have much
    Whether 80/20 rail by itself is strong enough is another question. I would add some 12 mm plate myself.
    Cheers
    Roger
    Aug 2014
    161
    I own a set of THK RSR rails, wide low profile, only have 2 ball tracks, they seem to have no play, very solid. I also own a set of Bosch Rexroth Rc1651 rails, 4 ball tracks. What the extra tracks provide is a larger contact area, translates to less wear at the same load. Download the books from Bosch, on Linear Motion Guides, products guide, and also they have a great book available for download, Linear Motion Handbook. I prefer the Bosch 4 track approach over THK or anyone else's 4 track design.
  1. RFQ for Race Parts
    By 2j-racing in forum RFQ (Request for Quote)
    Last Post: 03-15-2011, 04:44 AM
  2. Accurate Travel in Tight Spaces with Low Profile Redi-Rail Linear Guides
    By Pacific Bearing in forum News Announcements
    Last Post: 05-11-2010, 10:55 PM
  3. Race Cars
    By SCROMAL in forum Uncategorised CAM Discussion
    Last Post: 01-15-2006, 08:01 PM
  4. anybody race?
    By pyroracing85 in forum Hobby Discussion
    Last Post: 01-19-2005, 04:18 PM
