586,419 active members*
2,888 visitors online*
Thread: vacuum table
Results 1 to 5 of 5
    Feb 2011
    92
    vacuum table
    I'm going to first time buy a vacuum pump and make a small vacuum table DIY. I have not enough knowledge to choose the pump, but by some googling I found this one on ebay:
    called:
    2.5 CFM 1 Stage Rotary Vane Deep Vacuum Pump Refrigerant AC Air Condition HVAC
    Link:
    2 5 CFM 1 Stage Rotary Vane Deep Vacuum Pump Refrigerant AC Air Condition HVAC | eBay
    My use case is to have it holding corian dupont for small lithophane works (say, maximum 20cm x 30cm).
    Is this pump enough powerfull for the job I described please?
    35538
    Re: vacuum table
    You want an oil less pump, as that pump will fill you room with an oily mist.
    You want a pump with at least 2-3CFM, and one that can pull at least 25"Hg vacuum.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2007
    2134
    Re: vacuum table
    I have a couple of those, and they are good at pulling a vacuum, but as Gerry pointed out, they do mist enough oil it can be a problem.
    I've since bought a couple of oilless diaphragm vacuum pumps secondhand off ebay that work really well. I find they don't quite pull down as hard as the others, but they still reach a minimum of 25-26Hg.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Aug 2014
    889
    Re: vacuum table
    Get yourself a diaphragm vacuum pump. They are oil less. For light duty or light cuts in aluminum, 25-26Hg will be OK. For aggressive cuts I suggest 28-29 Hg. Of course keep in mind that total surface area is really what is determining the clamping force on your parts. So small pieces = you want lots of vacuum.
    Feb 2011
    92
    Re: vacuum table
    Thanks everybody, I'd go for an oil less low noise two stage pump with at least 2-3CFM, and one that can pull at least 25"Hg vacuum, what I learned from you ;-)
  1. Vacuum table help. Custom table for small acrylic parts.
    By czwalga in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-09-2014, 03:06 PM
  2. Vacuum table
    By Maderhobby in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-22-2012, 11:46 PM
  3. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  4. Vacuum Table where to next.
    By Steveb1307 in forum DIY CNC Router Table Machines
    Last Post: 11-29-2011, 04:56 PM
  5. Vacuum Table
    By vivagolf in forum DIY CNC Router Table Machines
    Last Post: 11-28-2008, 11:42 PM
