586,406 active members*
2,942 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > CHNC Spindle Bearing replacement?
Results 1 to 3 of 3
    Aug 2010
    190
    Talking CHNC Spindle Bearing replacement?
    Hello has anyone replaced the spindle bearings in a CHNC? I have most of it torn down but not I am wondering how I actually get the spindle bearing assembly out of the machine, so I press it out from the rear?
    Thanks!
    Aug 2010
    190
    Figured it out, check it out here
    http://www.cnczone.com/forums/vertic..._mach_3_a.html
    Oct 2015
    6
    Did you ever get an answer? I might need to replace my bearings soon.
  1. Perske spindle bearing replacement-how?
    By Stewey in forum Maintenance DIY Discussion
    Last Post: 08-28-2021, 10:31 AM
  2. Replies: 6
    Last Post: 03-14-2013, 07:59 AM
  3. Hardinge spindle bearing replacement?
    By vpmachine in forum Uncategorised MetalWorking Machines
    Last Post: 03-10-2010, 12:37 PM
  4. Spindle Bearing Replacement
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 09-08-2009, 12:12 AM
  5. Spindle bearing replacement
    By Rich 72 in forum Uncategorised MetalWorking Machines
    Last Post: 01-29-2008, 06:12 PM
