586,110 active members*
3,336 visitors online*
IndustryArena Forum > CAM Software > Surfcam > I am new to Surfcam!
    Dec 2014
    How I can be machined letters surfcam?
    May 2013
    142
    Re: I am new to Surfcam!
    Nc/ 2 Axis/ Contour/ Cut Control/ Change Cutting Method to On.
    Change Gouge Check to Single under the 2 Axis Options tab.
    Jan 2012
    97
    Create your text, practice with different fonts and sizes, truetype font is best.
    When you have what you think is good, go to EDIT/TEXT/EXPLODE select [within] and box in your text, then click [DONE]....
    That will turn your text into ordinary, line/circle/spline geometry, fix it up if you have to make it continuous and connected and you can machine it, probably using the pocket command......
    I hope that helps you....
    Apr 2003
    637
    I do it as Billetgrip has outlined above. Under 2 Axis options I set the Maximum feed between to 0.0000, the sort type to "None", and the gouge check to "Single". After exploding the text like machinster explained I then use NC/ 2 Axis/ Contour. Set the mask to the color of the previously exploded letters, then use Auto to let the program select the geometry. No need to fix up any non-connected entities. Each time a chain gap exceeds or overlaps a certain amount the program ask you to "end" or cancel, just hit "end" and it will continue until it selects all that you need cut. I save this tool path in the template as "Lettering". This has worked for about 20 years on just about every type of font I've tried.
    "I'm new to Surfcam!" - All I can say is: There is a cure but it takes years to heal. Sorry for your predicament, good luck.
  1. Surfcam, Inc. Releases SURFCAM 2014 R2
    By forjaco in forum Surfcam
    Last Post: 04-22-2014, 10:12 AM
  2. Why did you buy Surfcam?
    By Machining in forum Surfcam
    Last Post: 06-16-2012, 04:26 PM
  3. Surfcam 5.2 Anyone using it?
    By moldcore in forum Surfcam
    Last Post: 10-16-2011, 08:45 PM
  4. Surfcam 2-D SIM
    By Joseph Souza in forum Surfcam
    Last Post: 05-19-2011, 03:30 PM
  5. Surfcam help
    By jamesr in forum Uncategorised CAM Discussion
    Last Post: 12-13-2005, 02:10 PM
