586,741 active members*
3,039 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Lathe DRO installed. Suggestions to protect it?
Results 1 to 7 of 7
    Jun 2010
    1414
    I just installed a 6" DRO on my G0750G Lathe. I was thinking of a small metal shroud to protect it, but I would be curious to hear some other thoughts?
    Dec 2010
    1230
    Re: Lathe DRO installed. Suggestions to protect it?
    I never bothered to protect mine, but I mounted it vertically rather than horizontal. Never had any problems, and figured they are so cheap I'll just replace it if it messes up.
    Brian
    WOT Designs
    Jun 2010
    1414
    That is a good point. It wasn't more then $30 or so, but I figured it would be a smart idea to keep filings off it so it doesnt get jammed up. You mounted vertically on a quill?
    Nov 2009
    4415
    It is on the opposite side of the carriage than the cutting so chips should be minimal anyway. A simple piece of plastic or sheetmetal if you really thought it was necessary.
    A lazy man does it twice.
    7063
    What those scales REALLY don't like is anything wet. Get even a tiny bit of coolant or any kind of oil on the rail, and it'll stop working until you take it apart and clean it all up. I would definitely put a sheet-metal shield over the whole thing.
    Ray L.
    Jul 2011
    37
    One of the biggest things to guard on is pushing your tail stock up. I have bolts in the saddle to stop the tail stock before it can get to the scale.
    Dec 2010
    1230
    Quote Originally Posted by nateman_doo View Post
    I mean the box is laying down flat exposing the maximum surface area to chips and debris. I had enough room to mount the rail so only the thin edge points up.
    Brian
    WOT Designs
  1. Desktop Lathe suggestions
    By johntech in forum Mini Lathe
    Last Post: 08-30-2012, 10:18 PM
  2. Looking to buy CNC Lathe, any suggestions?
    By Polskiman in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2011, 03:33 PM
  3. CNC Lathe Suggestions
    By XFabbeck in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2010, 01:49 AM
  4. kingston cnc lathe data protect key
    By m.amir in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-02-2007, 07:34 PM
