586,530 active members*
3,342 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > connecting shielding
Results 1 to 14 of 14
    Sep 2014
    13
    i opened up my g540, to verify that the db9 connectors outer housing is not connected to anything. my idea is to solder a strip of copper across the housings, and solder a wire from that strip into the grounding in my 230 vac outlet. then i could wire the shielding to the chassis part in the connector. does that sound correct? here is a picture of the opened drive, showing what i would like to do:
    Jun 2006
    198
    Re: connecting shielding
    I'm pretty sure the shielding is already connected via the G540 top plate, which as far as I know is in steel or aluminum. So this would just not have any function.
    Sep 2014
    13
    no, it does not seem like the outer case is in direct contact with the ports.
    24223
    You should preferebly have a common star point ground plate set up where all the machine grounds, the service earth ground, and bonding conductors go to.
    Also when bonding is carried out, it is not practice to earth ground both ends of the shield.
    http://www.automation.siemens.com/do.../emv_r.pdf?p=1
    Al.
    Feb 2007
    505
    I hear you all but my own experience with shielded wire end up with me disconnecting them
    Jun 2006
    198
    All my cables are shielded and grounded at both ends, this makes for a great shielding on my machine.... I have never had any grounding faults on my machine...
    Feb 2007
    505
    If your using gecko cables that part of the cable is not connected as there is no contunuity from one end to the other ...there is no contuinity also from one connector to the next on the G-540.
    Quote Originally Posted by Beargesen View Post
    Feb 2007
    505
    shielding is usually grounded at the supply side only to avoid ground loops.
    Quote Originally Posted by IN-WondeR View Post
    24223
    Quote Originally Posted by Claude Boudreau View Post
    Used to be.
    See the Siemens link in post #4 ch6.
    This if the recommended equi-potential bonding is done as well.
    Al.
    Use pins 2, 3 or 4 on the DB-9 connector for grounding a shield. The shield should be unterminated at the motor end. Be careful connecting the shield wire to the DB-9 connector, don't let it touch any of the other pins or it will result in instant death for that axis drive.
    Feb 2007
    505
    Quote Originally Posted by Mariss Freimanis View Post
    Is this why on the gecko cables I dont measure continuity from one end connector to the other ?
    I mean the metalic part of the db9 from one end to the other end.
    Is this part connected to the shield? There is continuity on my db25...
    Jan 2020
    I working with the same thought, the DB9 on the Gecko G540 are not ground to anything as via opening the controller and viewing the metal shield terminator.
    I have search many times on the Web and YouTube, yes use Shield cable but never have seen terminating a wire to transfer the ground.
    24223
    The vast majority of my work was for customers, so I could not afford Intermittent problems.
    I used one of the very best shielded cables for encoders etc.
    Belden 9891. each pair individually shielded, OA shield plus single GND conductor. But very pricy$$$.
    I adopted the custom suggested by the Siemens publication, equi-potential bonding of machine, and grounding shield both ends.
    Never had a problem.
    Aug 2005
    1098
    Quote Originally Posted by aggies View Post
    So why don’t you connect the shied wire to the DB9 pins 2,3 or 4 as Marris suggests as they are connected to ground?
    Cheers
    Peter
    Sent from my iPhone using Tapatalk Pro
    Homann Designs - http://www.homanndesigns.com/store
  1. Ok to groud LED's with shielding ?
    By Jackal66 in forum CNC Machine Related Electronics
    Last Post: 07-22-2011, 12:57 AM
  2. DB9 shielding wiring
    By TheBulk in forum DIY CNC Router Table Machines
    Last Post: 03-11-2011, 03:42 AM
  3. EMI shielding
    By bigalow in forum CNC Machine Related Electronics
    Last Post: 02-29-2008, 03:18 PM
  4. Use of shielding gas on wood....
    By sntlewis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-13-2007, 10:06 PM
  5. Connection of shielding
    By cncuser1 in forum CNC Machine Related Electronics
    Last Post: 06-18-2006, 01:57 AM
