586,312 active members*
3,275 visitors online*
IndustryArena Forum > CAM Software > SheetCam > SheetCam producing CRAZY code
    Dec 2013
    Yesterday I was able to produce code no prblem then suddenly today I am getting code that I have never seen before.. What gives?
    I have tried making things in CAD (then DXF) and also in Inkscape (in SVG) Same problem with both meaning is lies within SheetCam somewhere. When I open files produced before today its fine.
    I also downloaded the most updated version. Same problem..
    attached are screen shots of said code. Thanks in advance.
    Mitch
    Jul 2005
    2415
    Re: SheetCam producing CRAZY code
    Either the MACH3 IJ MODE (config/General Config) got changed or you have the wrong POST processor.
  1. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  2. SheetCam doesn't write G code
    By CORTE in forum SheetCam
    Last Post: 11-30-2013, 09:54 PM
  3. CNC IS Producing
    By gualalasmooth in forum DIY CNC Router Table Machines
    Last Post: 01-03-2012, 02:31 AM
  4. SC7 not producing NC code
    By bevinp in forum SprutCAM
    Last Post: 09-10-2010, 08:59 AM
  5. sheetcam only creating g code for half the part.
    By turboboy in forum SheetCam
    Last Post: 10-03-2006, 01:37 AM
