586,544 active members*
2,524 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas TM1 control arm articulating
Results 1 to 8 of 8
    Sep 2011
    43
    Has anyone tried to articulate (hinge) the control arm on a Haas TM1? Some of the things I want to do require that the control moves out of the way. Not necessarily further out but away from the machine.
    John
    Feb 2009
    6028
    Re: Haas TM1 control arm articulating
    I put 2 TM2 pendants on floor pedestals.
    Dec 2011
    295
    On ebay there was a product that added about a foot of 4x4 tubing. That tube was connected to the stock tube by another black bearing. It also lowered the pendant about 5.5in. Not sure if there is enough wire inside the cabinet. Seemed to be handy for setup.
    Sep 2011
    43
    Thanks I'll look it up.
    John
    Sep 2011
    43
    Quote Originally Posted by LeWhite View Post
    Do you remember what they called it. Having trouble searching for it.
    John
    Feb 2009
    6028
    If you need longer cables, I just ordered any special ones from Haas for a VF6. Not to expensive either.
    Jul 2005
    12177
    Find yourself a Haas GR510 gantry router to look at; they have an articulated arm supporting the control. You might be able to do an adaptation using parts from this.
    Dec 2011
    295
    @JCP: I dont think it was a high production product. Just a section of square tubing 4 bolt holes and maybe 1.5in hole for the wires and the Haas parts to spin the pendant
  1. Ballscrew driven articulating head.
    By D.L in forum Linear and Rotary Motion
    Last Post: 06-17-2013, 03:28 PM
  2. New Haas control help please
    By hercules in forum Haas Lathes
    Last Post: 07-28-2009, 04:52 PM
  3. articulating arm buy or fab?
    By bullethead67 in forum Waterjet General Topics
    Last Post: 04-18-2009, 05:50 PM
  4. Looking for an articulating arm
    By loesch in forum CNC Machine Related Electronics
    Last Post: 10-30-2006, 03:00 AM
  5. Need help locating an articulating arm
    Last Post: 10-29-2006, 10:48 PM
