586,471 active members*
3,296 visitors online*
Thread: EG micro
Page 1 of 3 123
Results 1 to 20 of 57
    Mar 2006
    101
    EG micro
    I, as many of you around here have build a simple cnc, then another more advanced, then i saw how it could be improved, and decided i have to build yet another cnc
    So, wishes first
    hiwin linear rails
    chinese ballscrews
    stepper motors from previous cnc
    pretty ordinary stuff, except, main construction will be epoxy granite woohoo !
    simply amazing stuff that is, epoxy-granite mix, and after too much looking at other people projects i warmed up solidworks and start building
    too cut story short, this is what design i'm satisfied with looks like
    beside epoxy mix, metal parts embedded in it would be aluminum pieces, cause i can easily cut em on my cnc
    almost forgot ... dimensions
    working envelope would be something about 200x250x100mm and according to solidworks model it will be little over 100kg in weight !! seems robust enough
    just a short overview and i'll upload some more images soon
    Mar 2009
    39
    Re: EG micro
    I like you design.I am hoping to build a machine of similar size so your design is of
    interest to me.It looks well proportioned and should be very stiff.Portals look
    to be the best design for eg because of their closed loop design.Your bridge is nice
    and deep which should prevent bending under its own weight and the small travels should
    improve stiffness even more.Is there a reason for only 100mm of z travel?When you
    could easily lengthen the columns and/or reduce the depth of bridge to get 200mm/250mm
    without increasing weight or reducing stiffness much.
    What materials are you planning to machine?
    What size rails are you planning on using?
    I see an increasing number of router builds using poured and gravity leveled epoxy
    for railmounting.Maybe this is a possible rail mounting option.But I do have
    doubts about this methods precison and overall effect on machine stifness.A few links
    to machines using this method.
    BUILD LOG: A sufficiently strong machine
    BUILD LOG: Quite an Unusual one - Page 13
    In case you havent see them already these are imo the two best pdfs on eg and machine
    construction.
    Rapid machine tool design.A thesis on design and construction of an eg portal.Bostomatic
    BD12 year 1998.Has much general info on eg its properties,use,design with etc.
    DSpace@MIT: Rapid machine tool design
    German Castillo's thesis on developing and testing of an epoxy granite for machine tool use.
    In French.
    http://www.cnczone.com/forums/epoxy-...frame-104.html
    See post 3606.
    Together these two thesis answer many(but far from all) of the often asked questions asked
    about eg and machine construction.
    I hope you find some of the above helpful.This is a very interesting project.I will be
    watching with great interest.Thank you for posting it.Good luck with its construction.
    Mar 2006
    101
    Re: EG micro
    Thanks for interesting links !
    to answer your questions ...
    100mm of Z travel is more than i need, and i like how it looks in proportions, style at first place
    here are rails for X and Y, still need to get for Z axis, but will be the same size, 20mm, hiwin in this case
    and here are other components
    stepper motors are quite small, but should be sufficient (if not, easy upgrade)
    ballscrew are 12x4mm
    so, let's continue (or start actually) the process
    here is basic shape of mould for lower part
    after some thinking how to solve the problem of "attaching" aluminum pieces firmly into epoxy this is what i've come up with
    pretty simple, and with some of loctite in thread just to make sure, it's not coming apart ever
    this is all assembled
    there is not reason to save on bolts, so i used plenty
    base will be 100mm at thickest places
    and around 70mm at thinest
    next is exciting part of mixing epoxy to total of around 40kg of mix for this bad boy ...
    Mar 2006
    101
    Re: EG micro
    pouring, or actually, shoveling the epoxy mix
    here you see the tools i've use to compact it between all those gaps ...
    ...done
    here you can roughly see the size of stones, scale is in mm
    and fast forward it to interesting part ...
    you can see some mdf pieces stuck to aluminum, cause i didn't properly closed all the holes, and epoxy found it's way out ...
    but still, it turned out pretty great
    did a quick test and weight it, it turns out this bad boy is solid 42kg ... will make a stable base for sure
    Mar 2004
    1306
    Re: EG micro
    Good start. I have also been collecting rails, ballscrews etc for a little E/G emill of about this size.
    Mark
    Re: EG micro
    Nice!
    Skickat från min GT-I9300 via Tapatalk
    Aug 2014
    8
    Re: EG micro
    Nice job!
    You milled with another CNC the aluminum parts after made the EG block?
    Dec 2007
    2134
    Re: EG micro
    What a fascinating build, and great results!
    I've long toyed with the idea of an epoxy build and yours looks ideal.
    cheers, Ian
    Mar 2006
    101
    Re: EG micro
    yes, good old cnc did the job of surfacing the alu pieces
    Mar 2006
    101
    Re: EG micro
    epoxy-ing is not done yet ... so let's prepare mold for top piece ...
    you know the drill ...
    some assembly required ...
    done
    paint ...
    screw ...
    mix ...
    done ...
    demold ...
    test fit ....
    Jul 2009
    419
    Re: EG micro
    Thanks for the detailed pics, really nice to be able to follow this process closely!
    You make it look easy
    Could you share what mix you are using? It seems to be a mix of say 5 mm pebbles and sand and (estimate) 7%-10 or so epoxy?
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Mar 2004
    1306
    Re: EG micro
    Fantastic work you are doing there.
    Mark
    Jul 2009
    419
    Re: EG micro
    Quote Originally Posted by infinite8 View Post
    Seem like 50% granite < 5mm., 40% sand and 10% very fine sand. Need people who know german to verify.
    Awsome reading, thanks for sharing!
    The "very fine sand" is ground sand, translated directly as "rock flour"
    Sven
    Dec 2014
    Re: EG micro
    Die Trockenmischung besteht aus 50% Split mit einer maximalen Korngröße von 5mm, 40% Sand mit einer Korngröße von 0,2 bis 0,63mm und 10% Steinmehl mit einer Korngröße von 0,0063 bis 0,02 mm.
    The (Trockenmischung) dry mix mixture consists of 50% maximum grain size (Korngröße) of 5mm, 40% grain size between 0.2 till 0.63mm and 10% rock dust or fine sand grain size between 0.0063 till 0.02mm.
    Die Mischung wurde so gewählt um eine maximale Dichte mit so wenig wie möglich Lufteinschlüssen zu erhalten.
    The mixture is chosen in such way to maximize density and avoid as less as possible air intrapment.
    Very nice project by the way
    Jul 2009
    419
    Re: EG micro
    I was wondering:
    Did you take any provisions for the possibility that the ganty's feet did not come out plumb?
    And offcourse, would like to see more pics of the finished system
    Sven
    Oct 2009
    29
    Re: EG micro
    [QUOTE]
    Such a nice process I'm learning a lot from:
    I found that there're many ways about the mix and your mix seem very smooth.
    Here's my 2 cents about what I've found:
    From Tobias Merten and Michale Gunther's research on page 12, 5.1.3.1
    http://www.technikerschule-noerdling...N%DCRNBERG.pdf
    Ahh yes Tobias Merten.. He's got some videos on the tube. Really impressive machine, actually quite a similar design.
    https://www.youtube.com/watch?v=fDiEi2bOXgs
    Looking awesome by the way! Keep the updates coming
    Mar 2006
    101
    Re: EG micro
    feet were not flat right from the mold but it got cnced flat ...
    but i have another issue, as it turns out my cnc is not straight enough for my liking ...
    here is some testing, and at this configuration i need 2,5kg to slide this plate along rails ...
    hopefully i'll get it within acceptable tolerance and continue the build
    Mar 2006
    101
    Re: EG micro
    it's all about function, but it has to look pretty
    time to decorate it a little bit ...
    made a table ...
    did some assembly ...
    and made motor mounts ...
    Mar 2006
    101
    Re: EG micro
    if you see this on your table, you've made a wrong step somewhere along the line
    pretty tricky to get it back in, but now i know balls circulate in three separate circles, 16 of them in each ... how would i knew that otherwise :P
    and one more discovery about nut ... you can't cut threads in mounting holes, well actually, you can't redrill and enlarge them ... pretty hard material
    Jun 2010
    4256
    Re: Ball screw in bits
    Relax!
    Nothing that can't be solved with a credit card.
    I have disassembled a zero-backlash ball screw once, to get hypothetical gunge out, but I did it over a very big plastic tub, to catch all the balls. Eh - cleaned it all up, regreased the balls, reassembled, and it goes fine - within specs.
    The secrets are: don't lose any balls, and grease is great for keeping the balls in position while you fiddle.
    Cheers
    Roger
Page 1 of 3 123
  1. Micro drop
    By riche543 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-23-2012, 06:44 PM
  2. New DIY CNC Machine (micro)
    By edward.ford in forum DIY CNC Router Table Machines
    Last Post: 12-24-2009, 04:59 AM
  3. Micro Band Saw
    By tikka308 in forum Uncategorised MetalWorking Machines
    Last Post: 07-25-2007, 06:30 AM
  4. Bosch cnc micro 5
    By Olsson in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-16-2006, 06:57 PM
  5. micro-edm
    By roysol in forum Waterjet General Topics
    Last Post: 10-15-2003, 07:01 PM
