586,384 active members*
3,662 visitors online*
Results 1 to 15 of 15
    Mar 2004
    222
    NL2500-SY Part transfer.
    Hello everyone,
    How does one ensure the angular alignment of both spindle when doing a part transfer?
    Let's say we have bar that requires hex shape on both ends and we want the milled flats
    to be aligned on each end. We're off by a some degrees when we mill on the sub.
    Our actual need is to have a threaded holes on both ends with the same requirements, the holes must be aligned and they are not thru.
    I'm pretty new with the machine, is there some settings/parameter I can check before I start compensating in the code?
    Could somebody post a sample gcode I can look or suggest steps that I should take.
    BTW, we're using a CAM program.
    Any help would be greatly appreciated.
    mhel
    "This is intentionally left blank."
    Jun 2009
    28
    Re: NL2500-SY Part transfer.
    Hand wheel your sub spindle over with both spindles in turning mode, clamp the Chuck on the sub, then go to mdi, then to settings, select #21 for phase sync, then execute.
    Mar 2004
    222
    Thanks. But isn't M34 the equivalent of that? I'm suspecting the home of each spindle is not on the same angle.
    mhel
    Jun 2009
    28
    M34 turns on synchronization in the program, M36 turns it off. In the setting page you're setting the reference point between the 2 spindles so that they can sync up on the same point or feature.
    Mar 2004
    222
    We didn't get the chance to transfer today, we hit a snag. We're using a multitool holder and reached X limit drilling a 7" OD piece.
    Hopefully tomorrow I'll be able to see how synch works.
    Thanks.
    mhel
    Mar 2004
    222
    It took me a while, tool setup is a challenge for a newbie like me. I managed to complete the part transfer but synchronization didn't work.
    We called the Mori tech guy, he has the idea of what could be wrong but no solution at hand. He said that in turning mode the spindles
    are basically freewheel which meant that the encoder is only use for velocity and not positioning.
    Today, based on the tech guys idea, I tried the milling mode. I use:
    M45
    C0
    M245
    C0
    and do the transfer this time the spindles does not spin but just index and it seems to work.
    I have no idea if the transfer without spinning spindles is more accurate (transfer wise),
    but from the looks of it the holes are aligned unlike the synch options the angular offsets varies.
    I guess the thread can be closed now.
    mhel
    Jun 2009
    28
    That is one way of doing it and I frequently do something similar, I do it this way
    M45
    G28 H0.
    G0 G54 C0.
    M245
    G28 H0.
    G0 G55 C0.
    Then proceed with the pickup and make sure to add the M46 after the G330. This works fine when running slugs, for some reason I assumed you were bar feeding and parting off.
    Mar 2004
    222
    Thanks, I'll use that instead.
    mhel
    Dec 2014
    5
    Why not use MAPPS programming for the transfer ?
    Mar 2004
    222
    I'm not very familiar with MAPPS plus we're using CAM might as well do it in the CAM.
    I'm the CAM guy since I'm new at it too, I have to run my own program to prove it while learning the app so I could tell them it's doable.
    And to raise my credibility as a CAM guy :-)
    mhel
    Mar 2004
    222
    I just realized my post above didn't make sense. I'm using Topsolid7 lathe for our CAM and the part transfer is not fully supported.
    So I have to kinda have to hard code the transfer codes.
    mhel
    Nov 2004
    439
    earlier we use a text Block in our old CAM
    We Work also with TS7 but our PP for the NL is not ready.
    at the Moment I progammien only the milling mashines
    (*** UEBERGABE ANFANG ***)
    N250
    (UEBERGABE)
    G0 M5
    M9
    G98 G18 M46
    G54
    M211
    G0
    G28 V0
    G28 U0
    G0 Z0
    M51
    M251
    G97 S150 M3
    M34
    G53 G0 B?
    G4 U1.
    G53 B?
    G53 G98 G1 B? F1000
    G01 B? F120
    G04 U1.
    M59
    M259
    M210
    M05
    G4 U1.
    M11
    G4 U1.
    G59
    G28 B0
    G0 M5
    M36
    G53 Z?
    G99
    M01
    (*** UEBERGABE ENDE ***)
    Mar 2004
    222
    Quote Originally Posted by scherco View Post
    N250
    (UEBERGABE)
    G0 M5
    M9
    G98 G18 M46
    G54
    M211
    G0
    G28 V0
    G28 U0
    G0 Z0
    M51
    M251
    G97 S150 M3
    M34
    G53 G0 B?
    G4 U1.
    G53 B?
    G53 G98 G1 B? F1000
    G01 B? F120
    G04 U1.
    M59
    M259
    M210
    M05
    G4 U1.
    M11
    G4 U1.
    G59
    G28 B0
    G0 M5
    M36
    G53 Z?
    G99
    M01
    That's almost exactly what I do when I just do straight transfer and I am in turning mode, but with my original post I have to be in milling mode
    so as to make sure the holes are aligned since I'll be basically indexing in milling mode.
    mhel
    Nov 2004
    439
    this is from a Program we must have the same angle in first side and second side.
    I not programmed the NL for 3 Years
    N12
    (C-REIB)
    M8
    M69
    G98G19M45 here we are in milling
    G28H0
    G54
    G0T1064
    G0Y0
    G97S200M13
    S636
    G0Z2.8
    X18.
    C90.
    Z-2.35
    G89X-14.R-5.P500F63.6
    G0Z2.8
    G53X0
    G28V0.
    G53Z-400.
    M9
    M01
    N13
    (UEBERGABE)(transfer)
    G0M5
    M9
    G98G18M46
    G54
    G0T1111
    G28V0
    G28U0
    G0Z-23.5
    M51
    M251
    G0B-440.
    M73
    M211
    G04U1.
    M47
    G04U0.5
    M74
    G97S2000M4
    M34
    G0B-655.
    G4U1.
    G1B-670.1F1000
    M59
    M259
    M210
    G1U1.
    G0X14.
    G99
    G1X-0.2F0.08
    G0
    G53X0.
    G59
    G28B0
    G0M5
    M36
    G53Z-400.
    G99
    M01
    Mar 2004
    222
    Thanks, I did use the M34 to synch but it was off that's before I posted here. We're going to have a visit from a Mori tech I'll be asking him about it.
    I have another job, small part with the same requirements.
    mhel
  1. LT 10-MY part transfer
    By rwazana in forum Okuma
    Last Post: 10-29-2014, 12:42 PM
  2. Citizen Part Transfer
    By chet470 in forum CNC Swiss Screw Machines
    Last Post: 07-22-2010, 05:41 PM
  3. Part Transfer
    By littlebrewman in forum Mastercam
    Last Post: 05-04-2010, 12:33 PM
  4. Haas TL-25 part transfer
    By mcamiller in forum Haas Lathes
    Last Post: 09-22-2008, 08:09 PM
  5. 285 alarm after part transfer
    By Bobc007 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-19-2007, 03:13 AM
