586,500 active members*
1,860 visitors online*
Results 1 to 9 of 9
    Jun 2013
    75
    Spindle signal issues from mach3
    Hello forum.
    Upon figuring the tool table offsets and applying them, not using g43, thanks guys, I was now set on being able to control my motor from mach3. I read up on it and it seemed very straight forward, BUT, I cannot get my c10 bob to output any signal or voltage change when I turn the spindle on mach3. From what I read on countless manuals and have seen on YouTube, for step/dir control, you just need to enable the spindle, assign the pin for steps and dir, under the spindle tab you enable spindle control with step/dir, then do the motor tuning. I should be getting some signal now out of the c10 from those assigned pins when I turn the spindle on right? Am I missing something?
    Also, when I first stated I would set for example 1500 for the spindle amd click the cw f5 button, it would flash and the rpms would show about 1500, a little less. I don't know what I clicked or changed but I don't get any rpm change now, only the light flashing.
    Either way, I haven't been able to get any signal from the assigned pins.
    Any tips on my issue?
    Sent from my XT907 using Tapatalk
    Nov 2009
    4415
    Re: Spindle signal issues from mach3
    Are you using an S command or just simply putting the rpm you desire in the DRO?
    Give us a screenshot of your spindle setup page in Machs config.
    A lazy man does it twice.
    Nov 2009
    4415
    You will also have to have an rpm value in your spindle pulleys set up.
    Did you enter M3 S1000 (or whatever rpm you desire)?
    Jun 2013
    75
    Both, I would type in the rpm I wanted in the spindle window and hit enter, then hit the cw f5 button. I also would input m3 s1000 for example and the cw f5 light would flash, type in m5, and it would stop.
    At first the rpms would go up and then turn off with the m commands, but then it wouldn't. I'll go get that screen shot.
    Jun 2013
    75
    Attached re screen shots of my settings pages and the screen showing the m3 and m5 commands with rpm set, the spindle cw f5 flashing but no rpm displayed.
    You don't have a direction pin set for the spindle in ports and pins.
    Hoss
    Jun 2013
    75
    The dir pin would run the enable relay on the c6 board, step would control the speed of the spindle. I had both enabled when I started, pin 8 was step, pin 9 was dir, then I have the common wired in as well. Couldn't get signal changes from either pins. I assign pin 8 as my x step and hit the arrows on the key and the voltage goes up like it should, I just can't get any signal when it is assigned for spindle control.
    Jun 2013
    75
    I couldn't figure it out. I decided to just use output controls to enable and disable the spindle with water rpm I set manually. With this progress made, I was able to test out a fixed plate ATC that I will be making.
    If anybody can give me any tips to point me in the right direction for rpm/spindle speed control, please post it up.
    Just clarify if it was confusing previously, I am not getting any signal changes in the pins assign to the spindle when I input m3s1000 for example.
    -Alex
    Aug 2016
    185
    Quote Originally Posted by hoss2006 View Post
    Hoss
    Hey Hoss..
    Question..
    I am going to buy a C11G BOB.
    So it looks like the C11 board reads the PVM from pin 13 from MACH then creates an analogue voltage to drive the speed control.
    The C11 board has 2 relays that are on off depending on the state of pin 16.
    So here is my question..
    I think a M3 Command would set the dir pin to one state and the M4 would set it to the other. Therefore turning the relays off or on.
    Does that sound reasonable...
    I have an Harbor Freight X2 mill and would like to get fwd rev control maybe do some tapping. I am planning on putting a Hass effect sensor on the spindle to create the index pulse. If I get Mach 3 to read the rpm then a C3 would be unnecessary correct?
    Thanks for all of your posts . They help lots..
    Sent from my XT1635-01 using Tapatalk
  1. SPINDLE SPEED ARRIVAL SIGNAL issues for fanuc 3T controls
    By tapergear in forum Community Club House
    Last Post: 01-27-2014, 11:49 AM
  2. Mach3 output signal
    By salvanosalvador in forum Machines running Mach Software
    Last Post: 04-21-2013, 04:51 PM
  3. Setting up pwm signal for Spindle in Mach3 - copying setup from emc/linuxcnc.
    By craynerd in forum Mach Software (ArtSoft software)
    Last Post: 04-17-2012, 08:00 AM
  4. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
  5. Using the Err/Res signal to e-stop Mach3?
    By fatal-exception in forum Gecko Drives
    Last Post: 08-05-2010, 10:29 PM
