586,753 active members*
7,139 visitors online*
Results 1 to 3 of 3
    Nov 2013
    87
    Coolant Issue
    I'm probably missing something simple, but I filled up the sump on the Pulsar and then turned on the washdown nozzle, worked great. Then I went into mach and turned on flood coolant, this is where the issue happen, it took about 10 min but coolant got to the top of the flood coolant nose... almost. I've been letting it run and so far I've got nothing, it just sits almost at the top but never making it over the arc so I have coolant. I assume im missing something, but what?
    Jul 2007
    675
    Re: Coolant Issue
    Sounds like you got chips or something clogging your pump. Check the intake
    Nov 2013
    87
    Re: Coolant Issue
    nope, even simpler and I'm an idiot
    the nozzle was closed lol.
    side note though, anyone got a place I can order finer nozzles for the hose from? great volume right now but not enough oomph
  1. Replies: 4
    Last Post: 04-03-2024, 10:29 AM
  2. SuperMax Lathe Coolant pump issue
    By scubaru in forum Maintenance DIY Discussion
    Last Post: 03-28-2014, 05:32 PM
  3. Need Help With 6040 CNC Coolant Issue
    By EvoMan001 in forum Australia, New Zealand Club House
    Last Post: 05-27-2013, 10:32 AM
  4. EZ PATH II coolant issue
    By jaredsparks in forum Bridgeport / Romi Lathes
    Last Post: 03-20-2012, 02:18 AM
  5. Need Help with Coolant Issue!
    By Chaps in forum MetalWork Discussion
    Last Post: 03-22-2010, 03:34 PM
