586,495 active members*
3,042 visitors online*
    Oct 2014
    14
    Y-axis offsets on Haas ST20
    Banging my head against the wall trying to set a y axis tool offset on a Haas ST20-SSY. im sure the solution is right in front of my face but I can't figure it out for the life of me.
    what're the sequence of buttons I need to press to set that offset? does it just piggyback off of the already known x tool offsets? if so, why does the tool geometry reserve a place holder for a y axis offset? im very green, so go easy on me
    May 2013
    142
    Re: Y-axis offsets on Haas ST20
    I have to set the Y-axis offsets manually on our ST-10Y. I'm sure yours is the same.
    Just be sure to program a Y0. for each tool to keep them on center or you can shim them to center.
    Dec 2011
    34
    Quote Originally Posted by tyguidry View Post
    ok.i put an edge finder in a radial tool and find center of a dowel in the chuck and hit part zero set on the y axis.i believe that is how you set a "g54" y0.tjays how I do it and my "milled" features come out on centerline 90% of the time. To improve accuracy even more when your orientate c, how about set a different work coordinate system for each orientation of the chuck? Find y0 at each orientation of c and set zero so it's all centered..
  1. Haas ST20 No load HP/KW
    By mechplans in forum Haas Lathes
    Last Post: 11-19-2014, 03:27 PM
  2. Haas communication (Haas ST20)
    By Pottro563 in forum Haas Lathes
    Last Post: 10-31-2013, 05:56 PM
  3. Import dxf file to Haas ST20
    By brumback in forum Haas Lathes
    Last Post: 03-18-2013, 10:50 PM
  4. Info on radial tapping HAAS ST20 SSY
    By WESCO in forum Haas Lathes
    Last Post: 10-03-2012, 09:19 PM
  5. Haas ST20 Lathe Tool Offsets
    By Wod in forum Haas Mills
    Last Post: 02-07-2012, 06:12 AM
