587,012 active members*
3,707 visitors online*
Results 1 to 10 of 10
    Sep 2006
    5
    Question 401 servo alarm fanuc 6t
    I have a 1982 Mazak Micro slant 15 with the fanuc 6t control. The Machine
    constantly is getting the 401 servo alarm only when bringing the x axis down. The alarm seems to occur when the machine idles for 20 minutes or longer. I just had both servo motors rebuilt and replaced the pulse coder on the x axis. Sometime the machine will run great for a day or two then the alarm comes back. Anybody with any suggestions would be much appreciated.
    24223
    Hydraulic counter balance needs adjusting?
    Al.
    Sep 2006
    5
    Thanks alot for the quick response. Is the hydraulic counter balance located
    on the side of the servo? I see a small unit with hydraulic hoses running into it right next to the x axis servo motor.
    thanks again
    Shawn
    24223
    It is usually below the servo, there is a Mazak procedure to set pressure whilst running the X axis up & down.
    Al.
    Sep 2006
    5
    Is the procedure something I can find in the maintainence manuals and do myself or is it something a tech needs to do?
    24223
    If you have the maintenance manuals it should be in there, I believe you just need a pressure gauge to read while adjusting the pressure.
    Al.
    Sep 2006
    5
    Thanks for the info. I went to power up the machine and now it goes right into 401 servo before I even turn the hydraulics on. I opened the back door on the machine and noticed a red light (TGLS) lit up on what I believe is the servo amp board. The board is located on the other side of the velocity control. Would the TGLS light on pinpoint any one thing that could be wrong?
    Thanks Again
    Shawn
    24223
    Check the 3 phase into the drive and also check the overload reset.
    Al.
    Feb 2009
    Sir,
    I need the electrical wiring digram of Mazak make Micro Slant Turn 15 CNC Turning Center with Fanuc 6T. If some one has its machine manual and wiring diagram, pl. help me.
    regards,
    Mahajan
    Dec 2008
    239
    Quote Originally Posted by akm36 View Post
    Sir,
    regards,
    Mahajan
    I can provide you the manual and electrical diagram for fanuc 6t my mail id is [email protected] and contact number is +91-9430737981
