587,008 active members*
3,383 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 850/turning center - MASTER START REQUIRED
Results 1 to 8 of 8
    Dec 2014
    5
    The machine has been running nicely for years.
    In the middle of a part it halted.
    Upon restart everything came up but we have the message at the bottom of the display, "MASTER START REQUIRED".
    Of course we have pushed Master Start buttom, no response.
    We have scoured the manuals, no help that we can decipher.
    The display is functional, everything seems to have power.
    What should I do next?
    Thanks -
    Mar 2006
    31
    Re: Acramatic 850/turning center - MASTER START REQUIRED
    Im having the same issue, but I just bought the machine. Hydraulics are on, and chip conveyor will turn on, but thats as far as I can get. No axis movement. No one knows how to reset this alarm?????
    Dec 2014
    5
    My problem was finally diagnosed as a bad relay.
    Mar 2006
    31
    Figures. Thought I was purchasing a running machine. Thanks for the response.
    Mar 2006
    31
    Do you happen to remember which relay it was?
    Dec 2006
    585
    You need to get into the I/O and see what inputs are on and which ones are off. You should have an input for machine power on that tells the control that the machine is powered up. This will take the MASTER START REQUIRED message off. Look in the electrical prints for this input. Also look at the axis over travel switches inputs. Do you have 24VDC for the I/O??? Look in the control reference manual for the PROGRAM WARE section in the SERVICE screen.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Dec 2006
    585
    What did you find?? Is the machine and control running??? Let us know!!!!
    Mar 2006
    31
    No sir it is not. I found the relay that goes to the Master start, and swapped it out, and that didnt work. I havent had a chance to do anything else with it. I did notice the lights above the service switches are signaling to check the 5v on the analog power supply, but I havent tried to find that power supply yet. I did go into the service screen, and could see that it is showing the "master start" as OFF. I just havent had time to take it any further. Fortunately, were busy, but unfortunately Im short handed. With the machines Ive added, its causing me to have to run machines. lol
    Thanks for asking though.
  1. Super Max Machining Center 60 Parameter Description Required
    By prakashyaah in forum Drilling- and Milling Machines
    Last Post: 09-09-2014, 04:15 PM
  2. Super Max Machining Center 60 Parameter Description Required
    Last Post: 09-09-2014, 09:15 AM
  3. Required ROM IC's Data for FEMCO CNC Turning Center With Fanuc 10T Series
    By james anderson in forum Wood Lathes / Mills
    Last Post: 12-12-2012, 09:49 AM
  4. Can we start a master list of all tooling vendors
    By lm6769 in forum CNC Tooling
    Last Post: 02-20-2009, 11:07 PM
  5. Acramatic Contol on Cincinatti Talon Turning Center
    By Fudd in forum Uncategorised MetalWorking Machines
    Last Post: 06-02-2004, 05:19 AM
