Re: AMA25LV (G0704) CNC Touch Probe help !
The wiring is the simple part. Connect 1 end of a wire containing an alligator clip to a terminal marked GND on your BOB, connect another wire to an open input pin. Assign that pin as the probes input in Mach. Go to the diagnostics page, touch both wires together, do you see and LED go on or off? If it is on and goes off upon touching, change the state "active low" on that input pin. If it is off and the lights upon touching, you are ready to proceed with probing.
MSM has some great probing routines but costs an annual fee. I believe BigTex's screen set will have the probing routines you would need. I will check and get back.
After looking at your BOB, I believe the COM is what I referred to as the GND. Different manufacturers mark their boards differently.
A lazy man does it twice.
