Originally Posted by
the-niho
I have an issue with the machine, the error was displayed once or twice but now when i startup the machine it goes to reference parameters menu and it does not allow me to start the drivers without displaying an error.I also dont hear the air valve opening and hydraulic starting as it usually does.
Error shows in red square after it pops out of controller and it requieres a reboot.
originally machine shows it in German and it goes :
N76 8CA0 Referenzsignal oder strichzahl S fehlerhaft ( google translate- Reference signal or line number S faulty)
Module: Q:/commonTNC/sources/regel/dsperror.cpp
Line:328
Process: REGEL
Thread: DSPCLIENT
Errno : 2
Press the END key if you want to reboot the controll
Can anybody clear this for me ,this is the only machining center in my shop and the main machine ,and as it usually goes it makes problems when you are in a tight spot!! :drowning:
HELP
Thanx
