586,892 active members*
4,624 visitors online*
Results 1 to 8 of 8
    How to profile
    Hello Gentlemen!
    I'm brand new to the CNC world and find myself without any knowledge of CAM softwares.
    I feel silly asking such a simple question.. But how do I do tell BobCAD to profile this properly and leave just the circle in the middle? .Attachment 258792
    I've been trying for awhile with no success so I figured I would just ask the professionals.
    Thanks!
    James
    Dec 2008
    4548
    Re: How to profile
    Quote Originally Posted by Jamespvill View Post
    Hi James,
    Right click the "machine setup1" and choose "Mill 2 axis"....
    From there, select the face that's at the bottom of the cylinder for geometry and choose ok. Click next twice.
    From there select "pocketing".. Your current operations will now be a pocket and a profile finish....
    Compute that and run a simulation....
    There will be other ways to do things, like just selecting the bottom edge of the cylinder for a profile operation, Making an open pocket, etc, etc.....
    Start with that and come back with further questions,
    Re: How to profile
    BurrMan,
    Thanks for the info! Unfortunately, I seem to need additional hand-holding. So this is what I'm going for....Attachment 258808
    The best I can get so far....Attachment 258810
    Although an appealing shape, not quite what I want...
    I've got pocketing operations down pretty good, but this profiling continues to elude me...
    James
    Sep 2012
    1195
    Re: How to profile
    Here's a quick video using Profile instead of Pocket, but as with everything in CAM there are many ways to do the same thing. Pocketing gives you some more advanced strategies, but I think takes a bit more knowledge to use. In the "Profile Rough" toolpath option, you can "Side Rough" to clear out most of the material and then follow it up with a finishing pass. Video is at the link:
    https://files.secureserver.net/0smVA36E5CBj6j
    Re: How to profile
    Whoohoo!! I am one happy chappy! Attachment 258866
    Huge thanks to mmoe, thank you for the walk-though video, that was perfect!
    So onto my next question, the "Number of passes" is self explanatory, but I don't quite get the "Stock Remaining". I just fiddled with numbers until It was what I wanted it to be. Would someone mind elaborating on this for me? Attachment 258868
    Sep 2012
    1195
    Re: How to profile
    Stock remaining is basically how far from the finished edge of the part your material extends. If you have a 25mm circle in the middle, and a block of material that is 100mm square, you'll have somewhere around 45-50mm of "Stock Remaining" to remove going from the circle edge to the corner of the stock (diagonal is longer than the 37.5mm to the face of the stock at the side). To some degree, I just guess the dimension and correct it if I come up short or too big. It would be nice if there was a way to automate this parameter, but in truth you will eventually not use it very often once you learn some of the more advanced methods, so I understand why it would not be very high on their list of improvements. This is just the easiest method to get you started in my opinion.
    Re: How to profile
    Ah, That makes plenty of sense now. Thanks again for installing my training wheels. I will undoubtedly be back with more questions before my CNC adventure is all said and done.
    Dec 2011
    295
    Re: How to profile
    Tip: profile and pocket are interchangeable by reversing direction of cut (start point/direction in cam)
  1. Profile set up
    By Milton in forum Mach Mill
    Last Post: 12-29-2012, 03:37 PM
  2. 3D Profile Cut - Need Help
    By Malish in forum BobCad-Cam
    Last Post: 11-05-2012, 08:02 PM
  3. SX3 Profile
    By harvienielsen in forum Syil Products
    Last Post: 01-15-2011, 03:55 PM
  4. Profile
    By mrdipen in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 03-16-2008, 02:47 PM
  5. When I profile??
    By cncadmin in forum Uncategorised CAM Discussion
    Last Post: 06-26-2003, 04:39 PM
