586,299 active members*
3,832 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Simple ( i hope) cutter comp question
Results 1 to 5 of 5
    I have a simple cutter comp question. using a g41, why does my machine move in both the X and Y even though there is no X on the comp line? Below is the program that I am running. I have modified this from a Fanuc program. It runs fine except for that. It doesn really hurt anything, but I would rather it didn't do it. It only moves on the Y when it comes off cutter comp.
    Thanks Mike
    RPC-818-1 RETAINER BRACKET)
    (11-04-13 M.R.E.)
    N100G90G80G40G0
    T1M6(5/16 CARBIDE CUTTER)
    G54X-.2Y0S4000M3
    G43Z.1H1
    G1Z0F10.M8
    X.5625
    Y.07
    Y-.07
    Y0
    X-.2F20.
    G1Z-.15
    X.25
    X-.2
    G1G41Y-.225F10.
    X.25
    G3X.475Y0R.225
    G3X.25Y.225R.225
    G1X-.2
    G40Y0
    G90G0Z1.
    X3.5Y0
    G1Z0F20.
    X2.7375F10.
    Y.07
    Y-.07
    Y0
    X3.5F20.
    G1Z-.15
    X3.05
    X3.5
    G41G1Y.225
    X3.05
    G3X2.825Y0R.225
    G3X3.05Y-.225R.225
    G1X3.5
    G40Y0
    G90G0Z1.M9
    G53Y0H0M19
    M30
    35538
    Re: Simple ( i hope) cutter comp question
    That's the way that comp works. Comp is applied as the tool moves from the previous position to the position specified in the comp line. This is referred to as a lead-in move. The tool doesn't just move over the comp amount when comp is called.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Nov 2013
    402
    Gerry got it.
    Cut comp is moving from the previous X Y location.
    That's why you should have a 'lead-in', 'lead-out' move for cut comp.
    I do have a lead in and out. Still don't understand why it moves on 2 axises. Never worked that way on my Fanuc and Yasnac control. So if I ma milling a pices of stock to length, there is no way to get it to just make a comp move on only the X axis?
    Mike
    35538
    No, the lead in move will always move on 2 axis.
    The Lead-In move in your code is the one with the G41 in it.
    Gerry
  1. Milling cutter comp question
    By shags72 in forum Okuma
    Last Post: 10-13-2013, 06:53 AM
  2. Cutter Comp Question
    By behindpropeller in forum Haas Mills
    Last Post: 12-25-2009, 06:21 AM
  3. Cutter Comp Activation question
    By bigalexe in forum Fadal
    Last Post: 09-24-2008, 04:10 AM
  4. Fanuc Tip code 8 cutter comp question
    By demeyert in forum Fanuc
    Last Post: 04-04-2008, 02:03 PM
  5. SV2412 Cutter Comp Question
    By javajesus in forum Sharp CNC
    Last Post: 02-26-2008, 03:03 AM
