586,268 active members*
4,283 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > Sketch not extruding properly
Results 1 to 6 of 6
    Apr 2011
    21
    I am having a weird problem with a file I have been working on in Design Elements.
    I exported a multipart dxf and converted it into a usable file. All of the parts except one worked just fine, but the one absolutely refuses to extrude properly. When I extruded the plate only some of the holes are cut out. I have tried multiple things to solve the problem: I tried deleting and redrawing parts in the sketch. I have tried copying good objects but the duplicates don't work. I have tried separating the parts into separate sketches to no avail. I have tried analyzing the sketch and it passes. However if I draw a box around the object it renders perfectly (except it's reversed of course)
    Anyone have any idea on what to check to see where the problem is?
    Jun 2006
    3063
    Re: Sketch not extruding properly
    It's often a good idea to upload the part file along with your question so interested users can check the file and give you a more relevant answer.
    Mike
    Apr 2011
    21
    Here the part in question. Gave up trying to figure out what the issue was... I ended up just drawing the whole thing from scratch to get around the problem.
    Jun 2006
    3063
    I had a quick look and didn't see any issues with the sketch but ran out of time to check further. Working with the part was very slow on my system, much slower than it should have been for an object of this complexity. Can you share the original source file?
    Apr 2011
    21
    Quote Originally Posted by MichaelHenry View Post
    The frame bogs down on my machine as well. It's has to be all the filets in the file. As a dxf it's easy to work with and modify.
    Here's the original dxf that I broke into separate files.
    Jun 2006
    3063
    Played with the DXF a little and working with that was really sluggish. I noticed that my memory (12 MB) was about 90% in use so there must be something about the entities that is creating a problem. It almost seems like the fillets are made of hundreds of very small arcs, though they select fine as single fillet features. I'll play with it some more tomorrow and report back.
  1. Trouble with extruding-Please help
    By Forgewelder in forum Solidworks
    Last Post: 05-27-2014, 08:52 PM
  2. Extruding UHMW
    By sballard in forum Glass, Plastic and Stone
    Last Post: 08-01-2010, 07:10 AM
  3. extruding text
    By caddisfly in forum BobCad-Cam
    Last Post: 03-17-2010, 12:48 AM
  4. Need help in solidworks with extruding
    By brianklein in forum Solidworks
    Last Post: 10-14-2008, 07:02 PM
  5. Extruding Trouble
    By JOE65 in forum Autodesk
    Last Post: 02-23-2004, 06:47 PM
