586,455 active members*
3,422 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > no new computers have parallel?? experience on adding parallel port yourself?
    Sep 2014
    51
    Can you just add parallel port(s) to a regular stationary pc and make it work with mach3? Isn't there something about some port address' that need to be correct for it to work?
    I'll greatly appreciate any advice thx!
    Jun 2004
    6618
    Re: no new computers have parallel?? experience on adding parallel port yourself?
    You can use add in cards. You will find the correct port address to put into Mach 3 under the Device Manager in the Windows control panel after it is installed.
    Lee
  1. Adding a second parallel port for sherline setup
    By captianpattson in forum Benchtop Machines
    Last Post: 09-20-2012, 08:37 PM
  2. Adding pci parallel port
    By RedLabel in forum CNC Machine Related Electronics
    Last Post: 11-30-2009, 03:07 AM
  3. parallel port or parallel universe
    By bruno34 in forum Taig Mills / Lathes
    Last Post: 04-15-2009, 04:58 PM
  4. Where's the parallel port?
    By cdlenterprises in forum Mastercam
    Last Post: 01-21-2007, 12:23 AM
  5. 2nd PCI Parallel Port
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 11-22-2006, 09:17 PM
