586,682 active members*
2,776 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Starting to search some professional spindles (doubt)
Results 1 to 7 of 7
    Jul 2014
    23
    Lightbulb Starting to search some professional spindles (doubt)
    So, i am starting to search some good spindle to my 3 axis machine ( want to start machining metal ) and i have some doubts about it, like, can i control the speed of spindle and inverter combo in mach3 ? if not how can i use powerful spindles that can have the rpm controlled in g-code ? ( like 1 kw spindle or less, minimum 600w ), i only know the basics about eletronics, i am just finishing my mechanic technician course, so can someone give me a fast-learning about mach3 speed control ?
    24223
    Re: Starting to search some professional spindles (doubt)
    Mach uses a PWM signal for spindle control, for spindle controllers that have 0-10vdc analogue control, a convertor from PWM to analogue is required.
    There is also Modbus if the controller is capable.
    Al.
    Aug 2004
    780
    A professional spindle is one that uses a servo.
    A step/dir spindle will work fine.
    You should use a hw pulse generator, and a suitable servo.
    Jul 2014
    23
    i could use servo motors in the future, i dont have that type of knowlegde and money, as i have searched in ebay spindles with pwm control, they reach up to 400w only, maybe 600w, so with that in mind, could be better i use i dont know a spindle with converter, and if i need to change rpm in the middle of a program i make a obrigatory stop with a message text saying the rpm i should set them cicyle start again ?i have done a obrigatory stop once yesterday just for testing and worked
    Apr 2004
    5742
    There are pro-grade spindles for routers that aren't servos. Servo loops are only required for operations like rigid tapping, which need to synchronize the revolutions of the spindle with movement of an axis (usually Z), and they are used on mills, not routers. Pro-grade routers usually have a combination of a 3-phase router motor and a Variable Frequency Drive (VFD), which controls it. Some VFDs will also convert single-phase power to 3-phase, and can vary the speed using input from your machine controller. Hitachi makes VFDs that I've had good luck with. For the router/motors themselves, look for brands like Perske, Colombo, and Elte.
    Andrew Werby
    Website
    Jul 2014
    23
    Quote Originally Posted by awerby View Post
    can u help me find a vfd in ebay that is easier to install in mach3 or just one with manuals ? thanks in advance
    Feb 2007
    966
    Have you looked at ViperServo website
    2,3 and 7Hp spindles Perske Tekmotor and Colombo spindles are in stock.
    Larry
  1. Why are keling ATC spindles so much more expensive than er11 spindles?
    By sburck in forum Automation Technology Products
    Last Post: 12-20-2019, 02:32 PM
  2. Any reasonably priced (cheap) spindles other than the chinese spindles?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 11-05-2014, 11:16 PM
  3. Replies: 4
    Last Post: 05-14-2012, 03:54 AM
  4. Spindles de alta qualidade.High quality spindles.
    By Newtron in forum News Announcements
    Last Post: 09-21-2009, 08:33 PM
