586,161 active members*
3,231 visitors online*
    Aug 2010
    630
    XHC-HB04 MPG Pendant.
    I just purchased one of these units to use on my machine. I'm running LinuxCNC and they do have a module for it and it works. However, I have a question to those of you who use it on Mach3.
    Does Mach3 and the pendant work correctly when switch between Inch and mm units? By default, the unit powers up in mm mode, and only has 3 places after the decimal point. If you switch to Inch mode in Mach3, does it change to 4 places after the decimal point and loose the [mm] indicator on the pendant? If so, then maybe I can reverse engineer the codes needed to put the pendant into the proper mode and update the LinuxCNC module.
    Thanks, Connor
    Inner Vision Development Corp. - http://www.ivdc.com
    Website Design & Development. Shopping Carts, SEO and more!
    Apr 2007
    2580
    Re: XHC-HB04 MPG Pendant.
    Quote Originally Posted by Connor View Post
    Thanks, Connor
    Connor,
    Dunno man but I do know I wanna get a chance to play with that new toy of yours before too long on my CNC LOL... Good luck with it man!! Peace
    Pete
  1. Anyone used this as a pendant?
    By nightstang in forum DIY CNC Router Table Machines
    Last Post: 09-21-2012, 03:49 AM
  2. EMC + Pendant
    By AMTB in forum LinuxCNC (formerly EMC2)
    Last Post: 01-17-2011, 06:24 PM
  3. MPG pendant
    By troy676zsj in forum Fadal
    Last Post: 07-31-2006, 03:15 AM
