586,455 active members*
3,522 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0-M servo amplifier schematic alarms 401,414,424
Results 1 to 5 of 5
    Feb 2008
    26
    Hello, I have a Pratt &Whitney Tape drill Senior. I purchased it a few weeks ago. I got power hooked up, but I am getting 401, 414, 424, and 434 alarms. I hit reset the 401 clears out, but the servos will not come on. I checked diagnostic 727. It shows 00010000 improper current. I have checked the 220 volts coming in and used a phase meter to verify phase sequence. It all checks good. Does anyone have a schematic of the servo amp. It is a Fanuc 0-m, one servo amp powers all three axis. My Fanuc manuals doesn't have any electrical schematics. I need to check out the circuit. Any ideas? I also am seeking a diagnostic list so I can rule out any stuck switches. Is it possible my Fanuc memory is scrambled. My parameters look good. Thought about reset and power up to reset. I would appreciate any help.
    Aug 2007
    793
    Re: Fanuc 0-M servo amplifier schematic alarms 401,414,424
    alarm 727 - alarm of 7th axis?
    strange behaviour
    do you have parameters backup?
    I'd reload them in this case
    Oct 2014
    28
    FANUC O-M or FANUC Oi-M ?
    Feb 2008
    26
    It is a Fanuc 0-MB I ordered a servo manual from Fanuc. It came today. I have checked the voltages on the pins of the board. The only pin that is out of tolerance is the 20 volt pin. it checks 23 volts. I have also checked my power cables for shorts. All is good When I power up the control the VRDY stay on for about 5 seconds then it alarms out. I am getting a 414, 424 and a 434. All the diagnostics for this alarm are showing the same 00010000.(improper current). Any suggestions?
    Aug 2007
    793
    try do decouple motor and ballscrew (there is a coupling on motor's shaft)
    if problem stays on check encoder
  1. Fanuc Servo Alarms 401, 414, 424
    By sushrut in forum Fanuc
    Last Post: 10-20-2013, 09:31 PM
  2. Fanuc servo amplifier
    By hotrob1 in forum Fanuc
    Last Post: 04-27-2012, 01:58 AM
  3. Servo Amplifier FANUC
    By Antonio Arguijo in forum Fanuc
    Last Post: 12-07-2010, 03:53 AM
  4. Fanuc 401 & 414 Servo Alarms
    By crazycnc in forum Fanuc
    Last Post: 09-21-2010, 10:55 AM
  5. Fanuc 0t servo alarms
    By p1etaster in forum Fanuc
    Last Post: 11-05-2008, 09:26 PM
