586,838 active members*
2,503 visitors online*
IndustryArena Forum > CAM Software > Mastercam > MCX6 configuration
    Sep 2007
    100
    MCX6 configuration
    I am using MCX6 to post code for HAAS mills.
    When I try to use cutter comp at the machine control, often times I get an alarm.
    The factory told me it is because some program moves are equal to or less than .0002"
    I have tried changing some of the tolerances in the MCX6 System Configuration without any luck.
    As a result, I program for actual tool size (I am grinding with diamond tools) and must generate new code for every change in tool diameter.
    Can anyone help me out?
    Dec 2008
    3114
    Re: MCX6 configuration
    What "Comp Type" are you using ? (In Computer, In Control, or Wear)
    What Lead in/out settings you use for that comp type ?
    ( line distance, arc sweep, & arc size )
    - I do know that the arc sweep angle has created some problems for me on occasion
    -What setting do you use for cutter Roll at the corners ?
    What size of "cutter" are you talking about, & what amount of "adjustment" do you need to achieve ?
    Sep 2007
    100
    I have tried programming to the tool centerline (.500" end mill) and comp at control -.035" (.465" end mill).
    I have tried programming to edge of tool and enter actual diameter at control (.465" end mill).
    Errors happen way past point where tool enters the cut.
    I am contouring complex 3D surfaces with many small point to point moves.
    It is some of those small point to point moves that cause the alarm.
  1. Tweaking MCX6 post
    By Chrispbrown2255 in forum Post Processors for MC
    Last Post: 03-05-2014, 10:47 AM
  2. Help trim surfaces MCX6
    By tc26 in forum Mastercam
    Last Post: 08-21-2013, 08:49 PM
  3. Adding Custom Drill Cycle to MCX6
    By txcncman in forum Mastercam
    Last Post: 01-11-2013, 01:57 AM
  4. Replies: 1
    Last Post: 07-12-2010, 01:45 PM
  5. Help with 18i configuration
    By gbowne1 in forum Fanuc
    Last Post: 03-21-2010, 06:05 AM
