586,138 active members*
3,501 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Have parts, need to wire, what gauges to use?
    Nov 2014
    11
    Red face Have parts, need to wire, what gauges to use?
    I have my cnc built, have electronics in, but have had problem finding good information on what gauge wiring to use to
    wire my steppers to controllers, controllers to breakout board, all to power unit.
    Lady needs help!
    Oct 2014
    23
    Re: Have parts, need to wire, what gauges to use?
    Medina, I am going through the exact same process and have been researching also. I am going with 18 AWG stranded 4 conductor (4 wires in one cable run) shielded wire for my motors. Make sure you get stranded and not solid, since solid will start breaking down with the movement of the wire over time as your table is moving. Stranded is much more flexible. You can use the same gauge wire inside of your controller box for your remaining connectors, but I have chosen to go with solid wire since it will not need to be flexible in the controller box. Hope this helped. Stacey
    Nov 2014
    11
    Quote Originally Posted by SophieGirl View Post
    Thanks so much for your input. I really appreciate your input.
  1. Starreet thread gauges
    By cncorbust in forum MetalWork Discussion
    Last Post: 07-29-2014, 09:12 PM
  2. Indicator & Gauges to buy for 5410a
    By Gorgster in forum Benchtop Machines
    Last Post: 06-04-2014, 10:20 PM
  3. help me to wire CNC parts...
    By Mirvays in forum Stepper Motors / Drives
    Last Post: 01-14-2011, 11:07 PM
  4. Need some suggestions for wire cutter parts
    By mrman in forum CNC Wire Foam Cutter Machines
    Last Post: 08-09-2008, 07:45 PM
  5. Using Gauges in CamSoft
    By Steve Etter in forum CamSoft Products
    Last Post: 11-12-2003, 08:58 PM
