I often have to cut 2 sample out of the same piece of material, is there a way by using an offset command of some type to cut the first sample then the machine offset for the next part and cut it it with out having to unclamp the part rotate it or many re set the machine these are the 2 samples i would like to cut in the order i would want to cut them, i would like to nest them together as close as possible even having the cutter pat over lap itself on the insdie cut were the 2 samples are next to each other thanks in advance everyone looking forward to what you come up with i would like to offset on the y-axis towords the front of the machine (mazak 430A)
1 st sample
G17 G20 G40 G80
G90 G54
M6 T1 (scribe)
G90 G0 X1.1 Y-0.625
G0 Z1.0
S1000 M3
G1 Z0.45 F25.
X1.
Y0.625
G0 Z1.
X-0.9 Y-0.625
G1 Z0.45 F25.
X-1.
Y0.625
M6 T3 (cut)
M3 S930
G90 G0 X6.25 Y-0.75
G0 Z0.85 M08
G1 G41 X5.625 Y-0.75 D2 Z-0.875 F3.
X1.9364 G1 F10.
G3 X1.275 Y-0.5 I-0.6614 J-0.75
G1 X-1.275
G3 X-1.9364 Y-0.75 I0 J-1.
G1 X-5.875
Y0.75
X-1.9364
G3 X-1.275 Y0.5 I0.6614 J0.75
G1 X1.275
G3 X1.9364 Y0.75 I0 J1.
G1 X5.875
Y-0.75
X5.5
G0 Z10. M9
G0 G40 X0 Y3.5
G91 G28 Z0.
G91 G28 Y0.
G90
M30
Second sample
G17 G20 G40 G80
G90 G54
M6 T1 (scribe)
G90 G0 X1.1 Y-0.625
G0 Z1.0
S1000 M3
G1 Z0.35 F25.
X1.
Y0.625
G0 Z1.
X-0.9 Y-0.625
G1 Z0.35 F25.
X-1.
Y0.625
M6 T2 (cut)
M3 S930
G90 G0 X6.25 Y-0.75
G0 Z0.8 M08
G1 G41 X5.625 Y-0.75 D2 Z-0.875 F5.
X1.9364 G1 F12.
G1 X-1.275
G1 X-5.875
Y0.75
X-1.9364
G1 X1.275
G1 X5.875
Y-0.75
X5.5
G0 Z10. M9
G0 G40 X0 Y3.5
G91 G28 Z0.
G91 G28 Y0.
G90
M30
