The two samples shown are the same except the etching Z vales and the approach
Z for the profile. If you post a sketch I'll understand what you need better.
Attachment 258502
not sure if there is a tool comp running somewhere on the file you gave but when I run these 2 the parts they are different which is what I need, first part has a .5 inch reduced section second part has a 1 inch reduced section thanks again for your help
first sample should be
G17 G20 G40 G80
G54
G90
M6 T1 (scribe)
G0 X1.1 Y-0.3125
G0 Z1.
S1000 M3
G1 Z0.35 F25.
X1.
Y0.3125
G0 Z1.
X-0.9 Y-0.3125
G1 Z0.35 F25.
X-1.
Y0.3125
M6 T2 (cut)
M3 S930
G90
G0 G41 D2 X5.375 Y-0.593 Z1.0
G1 Z0.5 M08 F5.
X5.375 Y-0.3437 Z-0.875 F5.
X1.6977
G1 F12.
G3 X1.275 Y-0.25 I-0.4227 J-0.9063
G1 X-1.275
G3 X-1.6977 Y-0.3437 I0 J-1.
G1 X-5.625
Y0.3437
X-1.6977
G3 X-1.275 Y0.25 I0.4227 J0.9063
G1 X1.275
G3 X1.6977 Y0.3437 I0 J1.
G1 X5.875
Y-0.3437
X5.5
G0 Z10. M9
G0 G40 X0 Y3.5
G91
G28 Z0.
G91 G28 Y0.
M30
second part
G17 G20 G40 G80
G90 G54
M6 T1 (scribe)
G90 G0 X1.1 Y-0.625
G0 Z1.0
S1000 M3
G1 Z0.35 F25.
X1.
Y0.625
G0 Z1.
X-0.9 Y-0.625
G1 Z0.35 F25.
X-1.
Y0.625
M6 T2 (cut)
M3 S1550
G90 G0 X6.25 Y-0.75
G0 Z0.8 M08
G1 G41 X5.625 Y-0.75 D2 Z-0.875 F5.
X1.9364 G1 F12.
G3 X1.275 Y-0.5 I-0.6614 J-0.75
G1 X-1.275
G3 X-1.9364 Y-0.75 I0 J-1.
G1 X-5.875
Y0.75
X-1.9364
G3 X-1.275 Y0.5 I0.6614 J0.75
G1 X1.275
G3 X1.9364 Y0.75 I0 J1.
G1 X5.875
Y-0.75
X5.5
G0 Z10. M9
G0 G40 X0 Y3.5
G91 G28 Z0.
G91 G28 Y0.
G90
M30
m code with these 2 sample they cut undersize by approx .5 inch im using an .5 end mill not sure what im missing is it a tool comp somewhere i dont see or i should have?
thanks for your help mcode so i did as you instructed went a little futher then i noted i had not changed one of the ys thanks for your help i have a few more ?s well probbaly alot lol but the path is running fine thanks again for your help
