Hi guys,
I'm looking for a CAD/CAM software similar to PlasmaCam, easy to use and very practical. the way it works is very straight forward.
1- you import DXF file
2- Application displays a full screen work area view just like a canvas
3- you can copy, paste, rotate, resize, cut/link paths, draw new shape and manipulate parts anyway you like all within the same application.
4- then you can convert lines to cut paths
5- after that you can start cutting your parts, you don't have to regenerate paths or anything else. You can randomly select any object on the screen and just cut it.
So far, this is the easiest Cad-Cam controller software i've ever used, it works on the same concept of graphics applications such as Adobe Illustrator, FreeHand, CorelDraw, etc.. but instead of printing your artwork, you cut it. Other controller software such as Mach3, flashCut and the rest are not as intuetive as PlasmaCam.
I can modify my machine design to use any motion hardware that can support similar software, anything in the price range from 1 - 2000 US Dollars is OK with me.
