587,072 active members*
3,188 visitors online*
    Sep 2011
    17
    T-Slot Clamping Set
    I'm planning on buying a T-Slot clamping set but after watching this video:
    https://www.youtube.com/watch?v=cS_K...c&spfreload=10
    I'm a little worried that this type of T-Slot set will not fit on my CNC machine which is a hobby 6040 Chinese mill. I measured the gap of my slots and they are about 8.5mm which is not enough to get your finger in the slot as it was possible in the video. Looks like pro machines use bigger T-Slots. Can someone confirm that my suspicions are correct in terms of this kit:
    CLAMPING KIT - 58PCS - FOR MILLING MACHINE T-SLOT TABLE #P07
    most likely being inappropriate for my machine?
    Better yet, if someone could point me in the right direction of an appropriately sized clamping kit, that would be even better!
    Dec 2007
    2134
    Re: T-Slot Clamping Set
    From memory I needed to get M6 bolts to fit my 6040, even the M8 was too big. The muckmetal clamps ones that come supplied with the machine are M6.
    cheers, Ian
    Dec 2010
    1230
    Good luck. I've been looking for 1/4" clamping set for years. Had some that came with a crampy rotary table and LOVED them for clamping small parts on vise held fixture plates.
    Please post back if you find a source!
    Brian
    WOT Designs
    Sep 2011
    17
    Thanks, I wasn't aware there were sets for different types of T-Slots.
    As for their availability... I found some that should fit in the 8mm t-slot table:
    Clamping Kits
    So it seems they do exist.
    Dec 2010
    1230
    Nice! Wish I could find those in the US!
    Brian
    WOT Designs
    Dec 2007
    2134
    Quote Originally Posted by WOTDesigns View Post
    Brian
    WOT Designs
    That's so funny, normally it's us in OZ saying how good the Yanks have it, every product under the sun, and for a pittance of what we get slugged!
    cheers, Ian
  1. Need 8mm T-Slot clamping kit in Europe
    By Codeman in forum Benchtop Machines
    Last Post: 04-20-2010, 12:26 PM
  2. cutting a slot with a t-slot cutter
    By cncuser1 in forum Mastercam
    Last Post: 09-10-2008, 03:02 AM
  3. Where to buy loose 8mm T-Slot nuts and 6mm Clamping Studs
    By Hackman in forum Benchtop Machines
    Last Post: 09-08-2007, 05:57 PM
