586,408 active members*
2,942 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Help with wiring Drivers and breakout board please :)
    May 2008
    12
    Hey Everyone.
    I purchased a set of 4 NEMA 42's from Automation Technologies and a breakout board from China.
    I am trying to figure out how to wire it up to the drivers. I can't figure out Pulse, Dir, etc. hook ups to the board.
    I hope you guys can help me with this.
    Here is a photo of what I am trying to hook up.
    Also here is the manual for the breakout board.
    Thanks for any help in advance
    Dezi
    Attached Thumbnails Attached Thumbnails #SM403-5-axis interface board manual.pdf
    Jun 2006
    198
    Re: Help with wiring Drivers and breakout board please :)
    I must admit, the breakout board is far from the same quality as the drives and motors...
    But your motor outputs from your BOB need to be connected to PUL +- and DIR+-. How exactly they need to be connected should be explained in any documentation you recieved with your BOB.
    Your motors are connected to the drives on the drives A+- and B+-
    And your drives should be connected to AC on the AC input in the bottom.
    Jan 2007
    1795
    theres a chart in the pdf...
    example P6 = X step
    first photos shows P locations, and numbers
    from chart match them >>>>>> page 5
    just make first a layout and organize the part.. then draw where wires are running..then you will make it easy...
  1. Single TB6560 Drivers+Breakout board?
    By Zeppelin1007 in forum Stepper Motors / Drives
    Last Post: 04-22-2016, 07:42 AM
  2. Motors, Drivers & Breakout Board Wiring
    By OnezerO in forum Stepper Motors / Drives
    Last Post: 07-24-2014, 11:21 PM
  3. Connecting Breakout board to Stepper Drivers
    By bleker in forum Stepper Motors / Drives
    Last Post: 07-08-2014, 10:03 PM
  4. New breakout board and drivers, now stepper problem
    By jman 31 in forum DIY CNC Router Table Machines
    Last Post: 10-05-2013, 01:40 AM
  5. Wiring breakout board to old Isel Stepper drivers
    By TashadraCPT in forum Stepper Motors / Drives
    Last Post: 08-29-2012, 06:40 PM
