586,263 active members*
3,680 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > New spindle motor and controller for g0704
Results 1 to 8 of 8
    Jun 2005
    49
    After cooking the brush springs on my stock motor, then blowing the control board I decided to just stop faffing and buy a new motor and controller. Ended up with a 110st-5030 ac servo motor and controller. Looks a little overkill but it's lovely and smooth, silent and more torque than I can shake a stick at!
    Nov 2009
    4415
    Re: New spindle motor and controller for g0704
    Looks great!
    A lazy man does it twice.
    Oct 2012
    70
    Looks good.
    I had the 1800W one (M06030) on my G0704. Had 5000RPM at max speed with a 60:36 tooth HTD5M pulley arrangement.
    Pics:Attachment 258068
    The spindle ended up disintegrating (it was defective from factory) but never had a complaint with the motor.
    Good luck on your conversion!
    Jun 2005
    49
    Oh that looks like a lovely solution, might look at copying that! I believe the spindle is only capable of ~4krpm in stock form but maybe more for short periods?
    Oct 2012
    70
    The spindle bearings have been replaced with 7005AC bearings (my model is a BF20 - has a MT2 spindle and needs smaller bearings) and the top bearing with a better quality unit.
    I've run the thing for 30 minutes or so at max speed and no significant heat increase - only about 30 degrees above ambient.
    The 36T pulley happens to have a boss of exactly the same diameter as the bore in the top of the spindle. Then all that's needed to do is bore out the pulley to accept the spindle shaft, drill two M3 clearance holes ~42mm apart (this is from memory) and put two screws in.
    It's what I did, and worked fine.
    Mar 2008
    10
    I see ots long time, but if you see this, did you drive from PC/laptop. DId you use Mach3 in your set up.
    Darko
    Mar 2008
    10
    it has been long time, but I will try. I just got m06030 ac driver with motor. how did you drive your spindle. did you connected through computer. did you use Mach3.
    regards,
    Darko
    Feb 2016
    10
    Hi Darko,
    I'm considering getting an AC Servo for my spindle drive. Did you get yours sorted out? are you able to drive it in mach3?
    regards.
  1. Another failed G0704 motor controller
    By SgtSpyder in forum Benchtop Machines
    Last Post: 07-03-2017, 02:34 AM
  2. New Motor for G0704 (DC treadmill vs AC Spindle)
    By rusmannx in forum Benchtop Machines
    Last Post: 07-29-2014, 12:58 AM
  3. Spindle motor for G0704
    By Potatohead908 in forum Benchtop Machines
    Last Post: 02-16-2014, 06:24 AM
  4. Which motor and drive for g0704 spindle motor control
    By JeffsInventions in forum Benchtop Machines
    Last Post: 02-14-2013, 01:15 PM
  5. G0704 motor/controller/spindle questions
    By 109jb in forum Benchtop Machines
    Last Post: 11-13-2012, 05:52 AM
