Smarta$$ doesn't always translate well to text, but I was typing with a smile =D
Brian
WOT Designs
Brian
WOT Designs
Even GWizard can't accurately measure tool flex, stock flex and machine backlash.... So if YOU can.. awesome. More power to ya'
Edit: Posted, and refreshed, Brian made some great comments!
This forum is beyond help. It's a great shame, but there are just too many children here.
Ahhh, I would have never thought of that. I will give it a try. Thanks.
Donald
I think I seen a YouTube video on that, or someone in the HSM forum talked about it.
60 degree threads don't come to a sharp point. An internal thread has a pitch/8 wide flat (ideally rounded) at the base. The flat should actually get you closer to a correct thread within its side range though if it was ground too wide, it might cause grief with the finer pitches.
bob
Just an FYI, if you have tools setup and defined in SW and HSMXpress, the same tool library is used by Fusion 360.
Lee
