586,281 active members*
4,465 visitors online*
    Nov 2014
    Belleville spring help.
    Hello everyone, like to introduce myself briefly first before asking for help. My name is Daniel and I have 10+ cnc mills/lathes mostly Mori Seiki. Located in southern california and have over 40 years in the business. Mainly Aerospace/commercial.
    As for my problem, I had a few Belleville spring washers break on a MV-45. I've tried searching these everywhere with no luck. Looks like the nearest standard size is OD40mm x 20.4ID x 2.5 thick. However, my parts list indicates 40mm x 20.4 x 2.8. I've searched every website and called every place and no one carries 2.8mm thick in that size. Is my only option to have them custom made? Getting the set made is costing around $1,800.00. The set is 126pcs. Would dropping down to 2.5mm thick for all 126pcs and adding a few more washers to compensate for the .3mm difference(37.8mm total missing) be an option?
    Parts list: Main spindle head
    #12, Flush Spring Y73203 1 set, 40mm(1.574in) x 20.4 (.803) x 2.8 (.110)
    Any advice or experience with this would be greatly appreciated.
    Call SPS at 1-800-892-6258 Good people
  1. Belleville spring washer replacement
    By Fadal Error in forum Fadal
    Last Post: 03-06-2017, 12:38 PM
  2. Miyano TSV-35 drawbar Belleville spring replacement
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 10-15-2012, 06:00 PM
  3. Fixed Bearing w/ Belleville washers
    By CNCDevil in forum Linear and Rotary Motion
    Last Post: 04-16-2012, 02:44 PM
  4. PM Belleville washer replacement
    By fastfrank in forum Haas Mills
    Last Post: 02-27-2010, 02:15 PM
  5. Belleville washers on ball screws
    By Robin Hewitt in forum Uncategorised MetalWorking Machines
    Last Post: 02-19-2009, 06:36 PM
