586,608 active members*
3,691 visitors online*
    Sep 2009
    91
    Solidcam 2014 PROBLEM
    Hello Guys
    I have problem when i want to generate 5axis G-code alarm occurs see on the picture below.
    The machine is DMU 50evo.
    This happened only when i want to generate 5axis simultaneous G-code,with 3axis and 3+2 axis i haven't problems.
    Any ideas?
    Oct 2013
    64
    Re: Solidcam 2014 PROBLEM
    Mybe a postprosessor problem.
    Oct 2007
    499
    In the Machine Control tab set "Machine Limits" to "'No limits'. However, if your vmid file and MachSim truly reflect the kinematics and axis limits of your machine you may find that the machine alarms out when you run the code. Also you may need to use the alternative angle pair if the CAM job is taking your tilt axis the 'wrong' way.
    Sep 2009
    91
    I try but the same alarm occurs.Any other idea?
    Oct 2007
    499
    As I said, check your MachSim model and the vmid file. There may be a discrepancy between them. Also, there may be an issue with your post processor that is related to the vmid file.
  1. SolidCAM postprocessor 2014
    By solidcamx in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-08-2015, 07:01 PM
  2. Solidcam 2014 sp1
    By imachining-6061 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-02-2014, 04:47 AM
  3. G code SolidCam problem
    By zambrano in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-21-2013, 11:55 PM
  4. SolidCam Radius Problem
    By CNCOX in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-10-2009, 05:37 AM
